RE: Official HDX-450 Thread
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Official HDX-450 Thread
Page: <<   < prev  7 8 9 10 11 12 13 [14] 15 16   next >   >>
Login
RE: Official HDX-450 Thread - 1/23/2008 9:04:13 PM
FlyinLo
Status: offline
Read my last post, I finally got the bearing to move so it's flush now
_____________________________
-Hobbyzone Super Cub with Floats -Blade CP: bell hiller/alum swash
-HDX 450SE v3, Hobbywing ESC, HS65HG's, 2100T+9650
(in reply to MMatheny)
       Post #: 326
RE: Official HDX-450 Thread - 1/24/2008 5:24:16 PM
MMatheny
Status: offline
quote:
ORIGINAL: esmoglo
quote:
ORIGINAL: MMatheny
Well, it looks like it came with a Futaba T6XA - I don't believe that TX will work with eCCPM - I have one and bought a 7Ch because you can select the swash types. Someone correct me if I'm wrong, but I'm pretty sure I'm right. Unless it's a T6XAS, which I believe DOES have swash type settings.
That sucks! I hope I can use it? Any one know for sure?
Angelo
Well, it looks like a T6XAS, so I think it will work. Make sure the swash type is SR-3 or HR-3 (same thing, just named differently on different models of Futaba TXs).
Mike
"Never use your shins as a blade tracking device" - Mike
(in reply to esmoglo)
       Post #: 327
RE: Official HDX-450 Thread - 1/25/2008 1:41:00 AM
MMatheny
Status: offline
quote:
ORIGINAL: FlyinLo
OH, your picture didn't reflect that!
Mike
(in reply to FlyinLo)
       Post #: 328
RE: Official HDX-450 Thread - 1/25/2008 3:09:24 AM
FlyinLo
Status: offline
I quoted my previous post which contained that picture. Same old picture, I didn't bother taking a new one of the bearings sitting flush.
       Post #: 329
RE: Official HDX-450 Thread - 1/26/2008 1:35:52 AM
donh766
Status: offline
I am almos sure it has been covered, but I am new here and i just got an HDX 450 seV3 steup, and want to know does the trex sev2 tail assembly work on this kit...?
(in reply to Cyclic Hardover)
       Post #: 330
RE: Official HDX-450 Thread - 1/27/2008 10:40:38 PM
MMatheny
Status: offline
Yippiee!! Got my HDX450 finished today, and did some test flights in the back yard. Some pics of my heli included.
First thing, I could NOT get the tail to hold steady, kept wanted to yaw left. Took a closer look, and the darn pulley on the tail shaft was loose as a goose!! Put some locktite in the holes and screwed it down tight, removed all the rudder trim I had added, and viola! - holds nicely!!
Man, what a difference from my AxeCP - I immediately had more confidence (plus it helps when the heli stays where you put it!) I will never regret this upgrade!!
The AirThunder 2200 barely fits in the canopy - but, it won't go anywhere!! Got a cheap Art-Tech HH gyro on it, I figure if I need more, I can put this on my Axe CP, and get a better one.
On another note, I can't get much pirouette rate - what adjustments do I make to get it to spin faster (either way!)
EDIT - Well, it spins faster to the right than the left.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by MMatheny -- 1/28/2008 12:02:44 AM >
Mike
(in reply to donh766)
       Post #: 331
RE: Official HDX-450 Thread - 1/27/2008 11:37:24 PM
MMatheny
Status: offline
Does the T-Rex feathering shaft fit the HDX450?? I bent mine (on grass, no doubt!!) and I thought for sure I had ordered spares, but apparently didn't!!
Mike
       Post #: 332
RE: Official HDX-450 Thread - 1/27/2008 11:39:49 PM
MMatheny
Status: offline
I thought I read somewhere that if you spray your belt with silicone, it will last much longer. True or false??
Mike
       Post #: 333
RE: Official HDX-450 Thread - 1/28/2008 10:30:04 PM
restinpieces
Status: offline
nice pics . good color choice for the canopy. will be easy to see. i see those copterx helis with the blue canopy and wonder how your gonna see that on a nice sunny day.
haven't finished mine yet, still waiting on the dx6i. what tx/rx do you have? also, i think the feathering shafts for t-rex will fit
if you have a LHS. just take the old one with you to make sure.
i'll make sure to check the tail pulley again.
KEEP THE PICS COMING
I DON'T HAVE PROBLEMS,
I CREATE THEM!
       Post #: 334
RE: Official HDX-450 Thread - 1/28/2008 10:35:14 PM
restinpieces
Status: offline
oh yeah, do a search on belt lube on rcu and runryder. there's a big debate on that. seems like some swear by it, and some swear
at it.
I CREATE THEM!
(in reply to restinpieces)
       Post #: 335
RE: Official HDX-450 Thread - 1/28/2008 10:41:26 PM
FlyinLo
Status: offline
What size hex screwdriver do you guys use for the frame screws? The allen that came with the heli wore out fairly quickly and didn't seem to be the right size anyways.
All screws in this kit seem to strip very easily, I've had to use a pair of pliers more than once to remove them.
       Post #: 336
RE: Official HDX-450 Thread - 1/28/2008 10:54:36 PM
restinpieces
Status: offline
i had to try 3 or 4 different allen wrenches before i found one the fits. and it's still not as tight as i'd like. ticks me off to cause i bought a real nice little driver set from costco and the allen in it is sloppy. it's 2mm i think.
don't know if you have a ACE HARDWARE near you, but they have a good selection of really small screws in the one by me.
i might change them out to phillips.
I CREATE THEM!
       Post #: 337
RE: Official HDX-450 Thread - 1/28/2008 10:56:41 PM
MMatheny
Status: offline
quote:
ORIGINAL: restinpieces
Futaba 7CHP/CC Berg 7P with the USB programming cable (also works on my CC35 ESC)
The paint was something like Autumn Maple Metallic - got it at the local Hobby Lobby.
Someone else said the HDX feathering shaft is longer than the T-Rex. Man, all the extra parts I ordered and forgot those! Oh well, ordered 6 last night.
< Message edited by MMatheny -- 1/30/2008 5:36:44 PM >
Mike
       Post #: 338
RE: Official HDX-450 Thread - 1/28/2008 10:59:19 PM
MMatheny
Status: offline
quote:
ORIGINAL: FlyinLo
I believe they are 2.5mm. I went to Frys and got a nice kit with about 30 different small bits for $16. Also, did you see my post with a link to a site that sells complete stainless screw sets for many helis, including the HDX??
Mike
       Post #: 339
RE: Official HDX-450 Thread - 1/29/2008 12:01:30 PM
lrrps
Status: offline
My HDX 450 had a problem this sunday but fortunately without consequences.
I was flying it around without attempting any aerobatics and it was around 25 meter high when all of a sudden it started to spin.
I was thinking to myself, that was it this bird is dead in a matter of seconds, well I was wrong, to my surprise it landed smoothly on the grass.
After further inspection it was found that the tail drive gear front shaft has broken.
The day before the heli shook because the main blades were not tracking properly, I fixed the problem right after I found it but I don't know
it the breakage of the shaft has anything to do with the trembling of the heli.
Can someone shade a light on this?
Thanks.
       Post #: 340
RE: Official HDX-450 Thread - 1/29/2008 6:08:16 PM
MMatheny
