MMatheny
TX, USA Status: offline
Yeah, I have found some issues with the build video - it seems out of order - one section shows mounting the head and main gear, then the next section is mounting the servos, but the main gear is missing! Then next section is adjusting the servos, and the main gear is mysteriously back! I found out center your servos and figure out where the ball ends go BEFORE you mount them - they are impossible to work on after mounting. Also, keep the head and main gear off until you get the servos mounted! Also, here's a note I dropped to HeliDirect: ========== When I got my HDX450, the collar was tightened down high up on the shaft (maybe to keep the swash from banging around). Anyway, when I loosened it to move it down where it is supposed to be (the groove in the shaft) I noticed that there was a burr on the shaft where the setscrew was tightened down. I tried smoothing it down with 320 sandpaper, but couldn't get it as smooth as I would like - I had ordered a spare shaft when I ordered the heli, so I decided to use the spare shaft. Well, the new shaft has 2 flats on the shaft, not a groove! - worse, when I tighten the collar down to take out any slop, I don't believe the set screws are engaging the flat. Yes, I made sure I put the shaft in right side up - if I reverse it, the groove is down in the bearing race. I had 2 spacers in my package - was one an extra, or do both spaces go on top of the gear? ========== Now I'm concerned - the flat/groove area is so the setscrew doesn't leave a burr in the shaft so you can get parts off, but on my replacement shaft, the flat is a tad too high, and I'm pretty sure the setscrew is biting into the shaft below the flat area - if I measure the old and new shaft, the flat/groove is in the same place, so I'm wondering what is wrong/missing??
_____________________________
Mike "Never use your shins as a blade tracking device" - Mike
