hpi apollo
KY, USA Status: offline
from the stock 47/43 (if i remember right) to the 43-39 was a noticable difference in speed, also aided in traction control a tad, the only grinding was about 2mm to the side, very easy job to do, hard to screw up but i didnt have to grind the gearbox for the flywheel, if you want more bottom end then you would gear it lower not higher like a 45/41, does your car ever have troom to top out or does it run out of room first? if it runs out of room then definately gear it down, might i ask what clutch you are running? the hpi racing clutch is pretty good depending on where it is set, but the thing that made the most difference for me was modifying my 18ss, you might not want to do it but its free and it works very well, there are ahandful of modding threads on RCU alone that are good, and i myself have successfuly modded 4 engines, the 18ss was the one that worked the best, it would get you alot more power all the way through the power band, i have pics if you would like to see them on a side note, what brake are you running? i got some hyper 7 steel discs with some R40 brake pads and it always had alot of power to stop my car, heres a pic
_____________________________
95% of statistics are made up on the spot
