T34 Racing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Scale Racing >> T34 Racing Page: [1]
Login
T34 Racing - 6/12/2007 7:20:53 PM
JWQ500RC
Status: offline
I just got a World Models T34 to race in the Triangle Series in California. Anybody racing in this series have any suggestions or tips on building this plane. Looks very simple but thought there might be something I should look out for.
< Message edited by JWQ500RC -- 6/12/2007 9:45:46 PM >
       Post #: 1
RE: T34 Racing - 6/16/2007 10:54:50 AM
bkf1970
Status: offline
Hi JW; I just started racing in the Triangle series. Do You have a copy of the rules and guidelines? If not they are available online at T-34racing.com. The plane builds easily, but pay attention to the front wheel steering linkage, if not installed properly your steering will be backwards. You will need to replace the muffler bolt with threaded rod and lock nuts and secure the muffler with wire or tie straps, or weld the muffler together(remove the baffle before welding), the stock bolt WILL break. It is a good idea to reinforce the center wing joint with fiberglass or carbon fiber. When installing the main landing gear put the long side of the wire in the wing, this makes the landing gear shorter for reduced drag and better ground handling. When setting up your elevator servo and linkage put the control horn on the top of the elevator so the servo is pulling when you give up input(you may have to cut a new pushrod exit in the fuse above the horizontal stab). You may also want to replace the the stock pushrods with carbon fiber or metal. Most of the guys use tape to attach the canopy, some also tape the cowl, i use screws, i don't know if it matters much. Thats all i can think of right now, I hope to see you at Morgan Hill on the 23rd.
(in reply to JWQ500RC)
       Post #: 2
RE: T34 Racing - 6/16/2007 4:44:50 PM
JWQ500RC
Status: offline
Thanks for the information. I'm out of town for a wedding and will start on the plane next week. Don't know if I will make the 23rd, but will try.
Jim Williams
Visalia
(in reply to bkf1970)
       Post #: 3
RE: T34 Racing - 6/16/2007 6:06:18 PM
JPGale
Status: offline
bkf has given you some good tips here. I personally do not do anything other than put lots of glue on the wing joints I also leave the landing gear stock. Make sure your engines are in very good condition, what may be a good sport engine is too worn to be a race engine, we run these things over 16.5k. I replace the push rods and use z-bends (in fact a part of the rules) on the elevator, rudder and ailerons. if you set up servos as per part 18 on page 8 of the manual this will ensure that and then bring the rudder push rod out on that side of the plane. As you go through with the racing you will develop your own ideas and methods for each plane, I always put a flag on the bottom of mine for easy identification (see photo on the customer photos section of www.california-hobbies.com).
You will also need race numbers, I get mine from a club member at SCCMAS (morgan hill), but you can also get them I beleive from Steve at onsightsigns.com (bkf can you confirm). Come out to SCCMAS any Sunday afternoon, there is normally at least 1 or 2 racers there with a T-34, if I have one of mine I will be more than happy to show you everything I normally do. Also check out the SCCMAS.org website, there is a forum there where a fellow racer put build tips for a T-34 up including photos.
If you need planes or just a copy of the rules then contact Kevin Norred (T34RACING@YAHOO.COM) he is the race series director and he also is a world models distrubuter, I get my planes and spinners from him. I will also point him here when I see him tomorrow.
HTH
James
Race #78
It'll do racing team
SCCMAS Morgan Hill
_____________________________
James Gale - Team Norred Aero Products #78 www.t34racing.com
       Post #: 4
RE: T34 Racing - 6/18/2007 8:16:52 PM
T34RACING
Status: offline
Jim.
Sent you a email. Let me know if you didnt get it.
Thanks James for stepping up...See ya this weekned...I will try to have your parts for you
Kevin
KEVIN NORRED,
T-34 TRIANGLE SERIES COORDINATOR
       Post #: 5
RE: T34 Racing - 6/19/2007 4:22:13 AM
JWQ500RC
Status: offline
Thanks for all the good information. Just got back from Vegas, and ready to start building. As far as the engine it's brand new, I'll break it in this weekend, and should be ready for the next race in the series.
Kevin I got your email thanks.
Jim Williams
Visalia
(in reply to T34RACING)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.609RCU1
