RE: What airframe are you using with your A123 3S packs? (Full Version)
All Forums >> [Radios, Batteries, Clubhouse and more] >> Batteries & Chargers >> A123Racing Support
Message
dick Hanson -> RE: What airframe are you using with your A123 3S packs? (9/28/2007 7:06:27 PM)
after a lot of deeeep thought - I ordered another CellPro 4 and a dozen of the pigtails
this gives me two, CellPro 4 - one a 3 amp one a 4 amp and - I have a Dapter/ Astro Flite 12 deluxe setup -
so - in using various pack combos -I can charge up anything on site - quickly and balance if req'd
I am wiring my 6 cell packs with two sets of 3 cell charge plugs--for balance if the need arises -typically, I charge with the Dapter setup - but now I can balance or "top off " a pack by shifting to the Cell Pros.
My new model is one of my old SlimZlin designs from 1980's built very lite-with a 60 EFlite and 6 A123
790 squares AUW will b easily mid 6 lb
I got to get an autogyro too -seriously - I want one of the 3 blade dual rotor ones
RC Accessory -> RE: What airframe are you using with your A123 3S packs? (9/29/2007 2:17:17 AM)
Dick, that was a great aircraft in its day! :) Still have fond memories of my Runaround!
Evan Chapkis
RC Accessory, Inc.
everydayflyer -> RE: What airframe are you using with your A123 3S packs? (10/11/2007 5:14:15 PM)
My latest 3S A123 powered aircraft is an Ultra Mini Stick.
Hacker A30/16 ,APC 13X6.5E,(360 watts) Cool running 25A ESC (pushing it a bit).
AUW 30 oz.
Charles
Yak18 -> RE: What airframe are you using with your A123 3S packs? (10/27/2007 5:22:17 PM)
What a123 pack do we recommend for an 80 inch GP Ryan STM using this motor?
AXI 5330
digitalimage4u -> RE: What airframe are you using with your A123 3S packs? (3/10/2008 11:44:13 PM)
Why solder anything when using 123s, when you can use the power tubes from MODEL ELECTRONICS CORP? And if a cell goes bad you can replace it in 5 minutes.
DM
dirtybird -> RE: What airframe are you using with your A123 3S packs? (3/28/2008 4:58:38 PM)
quote:
ORIGINAL: digitalimage4u
DM
If you have 4 cells, it makes a long tube.
I'd like to see someone make a 4 pack BB with them in a parallel package.
They say not to solder to the batteries so a good BB makes sense.
Page: <<   < prev  1 [2]
Valid CSS!
SITE MAP!   : :   FORUM RULES
0.1572266
