#4 main shaft replacement
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Walkera Helis - Dragonfly, etc.. >> #4 main shaft replacement
Page: [1]
Login
#4 main shaft replacement - 6/12/2007 9:02:42 PM
kleaners
Status: offline
Can I use the main shaft from the honey bee fp to replace the shaft on the #4? I know many of the parts are interchangeable but the HB FP does not have the clip in the middle of the shaft like the #4 has.
       Post #: 1
RE: #4 main shaft replacement - 6/13/2007 5:31:36 AM
jtspin
Status: offline
I'm pretty sure they're the same - certainly close enough to try. I have a Hummingbird FP and a VNRII (same as the #4) and the shafts look the same to me without tearing down both helis to compare them. I just rebuilt my VNRII head with Dynam Hughs, HB, and VNRII parts. I haven't flown it yet, but it looks like it will work.
-JT
(in reply to kleaners)
       Post #: 2
RE: #4 main shaft replacement - 6/13/2007 5:41:37 AM
E_Heli
Status: offline
Both of them use 3mm main shaft, the #4 shaft has a slot for the C-clip to keep the shaft in place, the HB uses collar. There's enough room under the swash for the collar so it should work.
(in reply to jtspin)
       Post #: 3
RE: #4 main shaft replacement - 6/14/2007 1:15:16 AM
jtspin
Status: offline
D'oh! I was thinking more about the heads being different. Totally missed the part about the clip. Like E_Heli said, you could use the collar like the HB, or I suppose you could dremel/file/cut a groove in the HB shaft.
-JT
(in reply to E_Heli)
       Post #: 4
RE: #4 main shaft replacement - 6/14/2007 9:48:22 AM
andrew100
Status: offline
Hi,
Does anyone know if I can replace the GWS dragonfly main shaft with the Walkera #4 main shaft?
Andrew
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.484RCU5
