Rom gear leaking, what to check
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> Classic Pattern Flying >> Rom gear leaking, what to check
Page: [1]
Login
Rom gear leaking, what to check - 6/13/2007 1:42:07 AM
Tommygun
Status: online
I had problems with the Rom valve not working at all, so I replaced it with a Robart valve. But, for some reason, it still leaks down to 0 psi after about 20 minutes. I do get about 7 gear cycles when it's fully charged. Another odd thing is the pump gauge can't readout system pressure anymore- it always reads 0 even when there is enough power left for multiple cycles. And it's not the gauge; it checked good when blocking the fill line.
_____________________________
My other hobby: www.speedwake.com
       Post #: 1
RE: Rom gear leaking, what to check - 6/13/2007 2:58:01 AM
grotto2
Status: offline
Tommygun-
Take a squirt bottle filled with some soapy water and spray it around suspect areas. Bubbles will give away the leak.
-Ron
I finally got a tattoo. It reads, "Born too loose."
(in reply to Tommygun)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.172RCU5
