Futaba 6XAS and CPP Anyone?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> E-Flite Helicopters >> Futaba 6XAS and CPP Anyone?
Page: [1]
Login
Futaba 6XAS and CPP Anyone? - 6/14/2007 2:21:27 AM
Wnuk
Status: offline
I've been trying to setup my 6XAS with my CPP but have run into some issues. Has anyone else used this radio with their Pro successfully? If so can you share your settings?
Jim
       Post #: 1
RE: Futaba 6XAS and CPP Anyone? - 6/14/2007 3:42:58 AM
Georges Payne
Status: offline
Hello Jim,
The 6XAS Super has CCPM mixing and it should be able to work with your BCPP. What kind of problems are you having?
Did you look at the Futaba 6X FAQ? http://www.futabarc.com/faq/faq-6xsuper-q557.html
Good luck
Georges
_____________________________
If a man is standing in the middle of the forest speaking and there is no woman around to hear him, is he still wrong?
(in reply to Wnuk)
       Post #: 2
RE: Futaba 6XAS and CPP Anyone? - 6/14/2007 1:30:13 PM
Wnuk
Status: offline
The problem I'm having seems to be in the ccpm mixing. I have the correct swash selected (3), I setup elevator, aileron, & pitch servos individually and they all operate correctly until i plug them all into the receiver together. Then the elevator servo works opposite of what it should when applying throttle (collective). When I apply throttle, the elevator servo moves opposite of the pitch & aileron servos. Then when I use the elevator stick, it acts like I'm giving it throttle as all 3 servos move up & down in unison like it should when adding collective. I'm at a loss.
Jim
(in reply to Georges Payne)
       Post #: 3
RE: Futaba 6XAS and CPP Anyone? - 6/14/2007 2:34:57 PM
Georges Payne
Status: offline
Are you saying that the elevator servo works correctly when there is only one servo connected to channel 2 and no other servos are plugged in, but as soon as you connect all the other servos in their respective slot channel 2 is suddenly reversed, or you mean that channel 2 always work in reverse?
Have a look at this page. There's good info in there. http://www.jason.net/heli/ccpm.htm
This thread has some interesting info : http://www.rcgroups.com/forums/showthread.php?t=682685
Good luck
Georges
(in reply to Wnuk)
       Post #: 4
RE: Futaba 6XAS and CPP Anyone? - 6/14/2007 4:55:44 PM
Wnuk
Status: offline
That's exactly it George. Channel 2 works correctly when plugged in by itself. But it works in reverse when coupled with aileron & pitch. For the life of me I can't figure it out.
I'll have a look at the links you provided, thanks a bunch.
Jim
       Post #: 5
RE: Futaba 6XAS and CPP Anyone? - 6/14/2007 8:24:53 PM
Georges Payne
Status: offline
Now that's a Doosie!
(in reply to Wnuk)
       Post #: 6
RE: Futaba 6XAS and CPP Anyone? - 6/16/2007 2:18:38 PM
George1234
Status: offline
Wnuk: Here's what gets mine working, you can try these if you like.
Channels 1&3 reversed, remainder Normal
Swash A -60 E +60 P +34 type 3-S
George
       Post #: 7
RE: Futaba 6XAS and CPP Anyone? - 6/16/2007 6:23:01 PM
Wnuk
Status: offline
Thanks, I hope to get back to this tonite or tomorrow and try working it out witheveryones suggestions.
Jim
(in reply to George1234)
       Post #: 8
RE: Futaba 6XAS and CPP Anyone? - 6/20/2007 11:26:56 PM
stake
Status: offline
Could it be the transmitter is set up for the wrong stick mode? (mode1)
Chris
(in reply to Wnuk)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU5
