cmp giles 202 140
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Composites Fabrication And Repair >> cmp giles 202 140 Page: [1]
Login
cmp giles 202 140 - 6/14/2007 2:57:04 AM
nubrnchld
Status: offline
the giles 202 140 is a great flying plane. although on my third landing i came in a little hot. and bounced the plane and broke the carbon fiber gear . it was not a very hard landing although the carbon gear on the pilots right snapped. the problem is i have been waiting for three weeks for a replacement only to find out it may take another 3 because they are backordered . does anyone know where i can get a replacement set sooner. they can be carbon or aluminum. i just want to fly again.
bornnew
       Post #: 1
RE: cmp giles 202 140 - 6/21/2007 6:13:49 PM
BankYank
Status: offline
Might be kinda late but here is how to fix it.
Take some black thread and start wrapping it tightly around the break and go about a 1/2 to 3/4in on each side of the bend. once you have it wrapped use thin CA and soak all the thread. Let it dry and your ready to go. Chip Hide was selling some aluminum gear that would work on this plane. So when mine broke as your's have i called to order the gear from him and after telling him the problem he gave me the fix and the fix works great!
Pat
_____________________________
I tell ya she turned me into a newt she did
(in reply to nubrnchld)
       Post #: 2
RE: cmp giles 202 140 - 6/23/2007 4:06:02 AM
mnrcaerobat
Status: offline
many people have used the chip hyde cap x landing gear on this plane.
Brian
(in reply to BankYank)
       Post #: 3
RE: cmp giles 202 140 - 6/28/2007 4:57:30 PM
sax2ter
Status: offline
Pretty much everybody I know who has ever had carbon fiber landing gear on their planes, (including me), has experienced a similar failure at the same exact stress point on the gear. You don't have to ground your plane for many weeks waiting for some lame product support guy to eventually get you the part. My suggestion is to replace the carbon fiber gear with a comparable sized aluminum gear set. The one mentioned in the previous post will likely work, but there are also many sizes available as aftermarket replacements that will work fine. The difference in weight is minimal, especially since this isn't some small featherweight e-plane we're talking about here, and the aluminum will take a pounding without cracking or bending. Just make sure the aluminum set you buy is a close approximate match in height, so you don't have to worry about prop strikes. Also, they should be approximately the same width as the fuse, or similar in dimension to your OEM gear. Hope this helps.
Joseph in Ojai, CA
(in reply to mnrcaerobat)
       Post #: 4
RE: cmp giles 202 140 - 7/12/2007 2:57:45 AM
nubrnchld
Status: offline
Thanks Brian the landing gear you sent me works great, slapped on some flat black paint and they look good as new!!!!
(in reply to sax2ter)
       Post #: 5
RE: cmp giles 202 140 - 10/28/2007 3:21:59 PM
zwituku
Status: offline
What kind of thread are you referring to?
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.531RCU5
