BTE DELTA VORTEX CG QUESTION???????
Tower Hobbies
Logged in as Guest
  Printable Version
KRILL Yak 55M - RTF
Seller:  Jecarte
Details:   $6,850.00   |  9/28/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> BTE DELTA VORTEX CG QUESTION???????
Page: [1]
Login
BTE DELTA VORTEX CG QUESTION??????? - 6/14/2007 3:28:30 AM
airbusdrvr
Status: online
I am in the planning stage of building a Bruce Tharpe Engineering Delta Vortex, http://www.btemodels.com/vortex.html. The fixed gear will be replaced with retracts which means the nose gear will retract into the compartment just aft of the engine bulkhead that was designed for the fuel tank. Using an engine test stand, I confirmed that my engine will run with the fuel tank placed aft of the nose wheel compartment. This location places the tank at or barely forward of the CG instead of the original eight to nine inches forward of the CG. Now my question. CG locations on most kits and ARFs are shown with all equipment installed but no fuel. If the fuel tank is now at the CG location and fuel weight will never affect CG, do I still use the CG location in the plans that assumes the tank is forward of the CG. The recommended tank size for this model is 14oz to 16oz.
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: BTE DELTA VORTEX CG QUESTION??????? - 6/14/2007 5:33:34 AM
combatpigg
Status: online
You can't escape the fact that you will have to fly the plane with fuel in the tank. If having fuel in the tank causes the CG to be aft of what is called for, then you will most likely have to move the engine forward to compensate.
_____________________________
Led Zeppelin is NOT "old fogie" music.
(in reply to airbusdrvr)
       Post #: 2
RE: BTE DELTA VORTEX CG QUESTION??????? - 6/15/2007 3:17:38 AM
wvarn1957
Status: offline
I have the BTE Delta Vortex with retracts, powered with a YS 61R. The tank is on the CG to allow for installation of the nose wheel retract. Balance it as called for on the plans(21" to 22" from the trailing edge) without fuel and the retracts up. Mine is balanced at the more reaward limit because when the nose gear is down it shifts the balance point foward. How much it shifts is dependent on the size and weight of the nose wheel.
< Message edited by wvarn1957 -- 6/15/2007 3:18:35 AM >
W W Varnado
(in reply to combatpigg)
       Post #: 3
RE: BTE DELTA VORTEX CG QUESTION??????? - 6/15/2007 11:16:51 AM
da Rock
Status: online
Very often, when a tank is placed "on the CG" it's actually not. Most designers consider that the fuel rides around in the back of the tank most of the time. So they usually don't put the center of the tank on the expected CG. It's a bit safer to place it with the center of the tank somewhat forward the expected CG. It often depends on the size of the fuel tank in relationship to the size of the airplane.
(in reply to wvarn1957)
       Post #: 4
RE: BTE DELTA VORTEX CG QUESTION??????? - 6/15/2007 11:25:04 AM
airbusdrvr
Status: online
I sent an e-mail to the designer/owner of the kit, Bruce Tharpe, and received the following reply.
"Use that CG range regardless of fuel tank position. You will have the benefit of no CG shift with fuel burn - nice!
___________________________________
BTE | Bruce Tharpe | Owner "
(in reply to da Rock)
       Post #: 5
RE: BTE DELTA VORTEX CG QUESTION??????? - 3/30/2008 5:40:25 PM
gcb069
Status: offline
What retracts are you usin?
       Post #: 6
RE: BTE DELTA VORTEX CG QUESTION??????? - 3/30/2008 10:53:49 PM
airbusdrvr
Status: online
Spring Air Retracts with Robart 3/8" struts.
(in reply to gcb069)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
6.750RCU1
