20% vs. 30% nitro
Tower Hobbies
Logged in as Guest
  Printable Version
Team Losi 8ight-T - Kit
Seller:  fcbuilder
Details:   $1.50   |  11/18/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> 20% vs. 30% nitro
Page: [1] 2 3   next >   >>
Login
20% vs. 30% nitro - 6/14/2007 4:50:28 AM
markhat250
Status: offline
I've been using 30, but getting a new engine tomorrow. I want to break it in with 20% because I think it will be getting better lubricated, and the performance will be relativley the same.
Someone correct me if I am wrong. Is 20% just a better all the way around better way to go?
       Post #: 1
RE: 20% vs. 30% nitro - 6/14/2007 4:52:15 AM
Conti027
Status: offline
i would say yes. i used 10% in mine cause i like to keep my engines for a pretty long time and im not to anal about speed most the time
hey markhat i see you live in AZ so come join us at
http://www.az-rcfreaks.com/freaks/index.php
unless you have already
< Message edited by Conti027 -- 6/14/2007 4:53:38 AM >
(in reply to markhat250)
       Post #: 2
RE: 20% vs. 30% nitro - 6/14/2007 5:05:05 AM
markhat250
Status: offline
I'll head over to that site. Cool. I pretty much race at SRS. I'll start hitting Papago's new track layout if he gets it put back together, and maybe the Pit, but mostly SRS.
I'm hoping to hear a lot of thoughts on this nitro thread. I am due for fuel and want a change from the Sidewinder 30 I've been using.
(in reply to Conti027)
       Post #: 3
RE: 20% vs. 30% nitro - 6/14/2007 5:08:41 AM
Conti027
Status: offline
well all i can say is join the site i gave my input already
       Post #: 4
RE: 20% vs. 30% nitro - 6/14/2007 5:19:15 AM
Super_Dave
Status: offline
The only thing that 30% fuel wears out faster is your connecting rod and bearings. Your piston and sleeve is still getting the same exact lubrication regardless of the nitro % (as long as the fuel your using has good quality lubricants) so the piston and sleeve will last just as long on 30% as it will on 20%. There might be a slight difference probably due to the engine reaching higher RPMs but thats about it.
Theres still nothing wrong with 20% nitro. With off-road its more about driver and setup than it is about power.
       Post #: 5
RE: 20% vs. 30% nitro - 6/14/2007 5:25:02 AM
Conti027
Status: offline
30% heats up more also
(in reply to Super_Dave)
       Post #: 6
RE: 20% vs. 30% nitro - 6/14/2007 5:29:35 AM
markhat250
Status: offline
You said it.....driver set up. I'm convinced I won't go any faster cuz of the fuel, so why not have better lubricant?? This is the point I am trying to make, just looking for someone to give a good argument in favor of 30%.
       Post #: 7
RE: 20% vs. 30% nitro - 6/14/2007 5:35:06 AM
Conti027
Status: offline
well it would go a bit faster
       Post #: 8
RE: 20% vs. 30% nitro - 6/14/2007 6:57:56 AM
1/8racer
Status: offline
and run cooler not hotter
       Post #: 9
RE: 20% vs. 30% nitro - 6/14/2007 7:03:20 AM
TGreg
Status: offline
guys honestly if your running 30% youll be better off, i had three RTR engines on 20% and now im on my second race engine on 30%. It runs cooler (yes i mean cooler) easier to tune, and they last just as long if not longer than my 20% engines. honestly ppl freak out about 30% but its not that much of a big deal, just use the 30% and enjoy the benifits.
_____________________________
Cen Matrix Factory Racing Edition Pro Kit, STS D21T, Jammin' JP-3 Pipe, 14t Clutch bell, Panther K2 Softs.
(in reply to 1/8racer)
       Post #: 10
RE: 20% vs. 30% nitro - 6/14/2007 2:10:46 PM
lanerbrainer205
Status: offline
Markhat250 it has been proven that 30% fuel is wayyyyy higher in performance than 20%. They dynoed it in RC Driver, and they said it has the same lubrication content as 20% fuel.... just food for thought man.
(in reply to TGreg)
       Post #: 11
RE: 20% vs. 30% nitro - 6/14/2007 4:23:36 PM
RBMike
Status: offline
I like 25%. Most of the Italian motors are designed for 25%. Byrons race 25% has been working well for me for a long time.
B44, RC8, MBX5-Prospec, RB C6,S7II,S5,WS71,S7europa
(in reply to lanerbrainer205)
       Post #: 12
RE: 20% vs. 30% nitro - 6/14/2007 4:46:15 PM
mozzzy_2000
Status: offline
yeah I think 25% is the best compromise in turns of performance and engine life.
(in reply to RBMike)
       Post #: 13
RE: 20% vs. 30% nitro - 6/14/2007 8:25:09 PM
Conti027
Status: offline
hmm i guess i was wrong but im pretty sure i read lot that 30% gets hotter
(in reply to mozzzy_2000)
       Post #: 14
RE: 20% vs. 30% nitro - 6/14/2007 9:20:07 PM
pete8541
Status: offline
My engines have all run cooler on 30% and there is an increse in proformance
       Post #: 15
RE: 20% vs. 30% nitro - 6/14/2007 9:28:13 PM
lanerbrainer205
Status: offline
my engines run cooler with 30% also actually its 33%
(in reply to pete8541)
       Post #: 16
RE: 20% vs. 30% nitro - 6/15/2007 12:23:14 AM
TGreg
Status: offline
i promise you that there is no drop in engine life, just gains in performance. the only engine life drop you could see is that it might bite the dirt a 1/4th of a gallon sooner.
nitro has nothing to do with engine life, its the oil type and oil percent that effects engine life..
grow some and get the 30%.
most ppl run 20% because of EFRA...
       Post #: 17
RE: 20% vs. 30% nitro - 6/15/2007 12:24:16 AM
TGreg
Status: offline
I'm actually thinking of trying that O'Donnels 60% Race Blend. Of coarse id shimm my engine accordenly.
(in reply to TGreg)
