bob27s
OH, USA Status: offline
quote:
ORIGINAL: Capn America Bob, We are getting ready for our first club pylon event here. rules are base on 424 with the options to run a different muffler and up to a .46. I have a viper set up with a tt40 and a super tiger .46 lying around. It was apperent after practice last night I need more power to keep from getting lapped. I need to order up a Jett stream today and wante to know what you thought of the 2 motor possibilities, stay with the tt40 or go to the st46, dont really see myself ordering one for each at this point... The rules outlawed my Jett 46 already with the retail price limit so Im looking for suggestions. Also do you know what sealant is used in the jett tanks? Im repairing one and silicone does not seem to be very fuel proof. Thanks You must have some tough competition. What are other guys flying ? Usually a Q-500 with a TT40 is pretty quick (110 mph range) when set up for 424. stock muffler and a 9x6 prop. Set up this way, the TT40 should turn between 16,300 and 16,500 on the ground. If you are not seeing at least 16K from your TT40.... you are at a loss. Can sometimes be fixed with some bench running with a clipped 9x6 prop or an 8" prop .... let the engine scream up around 17,500 for a tank or two... then go back to the full 9x6. You may want to check with Dub on the muffler..... he has been running about a week on parts deliveries. If you are allowed to used the tuned muffler...... I would go with the TT40 ---- the TT40 and 46 love the Jett-stream. Instant 1200 rpm increase from what ever the engine is turning now. You would want to us a 9x6, 9x7 or maybe a 8.75x8 prop. You want to keep the rpm pretty much as I noted above --- ground peak just under 17,000 rpm... down no lower than 16,000 rpm. Find peak (what ever it ends up being), back off on the needle 500 rpm --- fly it. Set up like this, you should see 110-120 mph on the race course easily. As for the fuel tank..... I do not recall there being sealant in there, other than a very thin film of adheasive around where the stopper is pressed in. Dub may be putting a tiny bit of GOOP or RTV silicone on the vent/pressure tube. The tanks are generally not repairable if the bladder breaks or the stopper area is damaged. If the vent tube is the issue, that one is easy... just stuff it back into the hole... it is a tight fit, and there will be no fuel to leak out anyway. Parting thought.... Racing is not always won by the fastest airplane. You have to fly smooth, stay on the course, not make any sudden control inputs. Every time you hit the elevator or ailerons it is like putting on the brakes. Practice is the main key. A reliable and consistant aircraft/engine is the other key. You will see many folks ruin their chances trying to get an extra 100rpm and end up with a lean flight...... others will set up the plane way too sensitive and it will be all over the sky... stay consistant, stay smooth... and practice. Bob Brassell
< Message edited by bob27s -- 6/14/2007 4:37:38 PM >
_____________________________
Bob Brassell Jett Engineering - Engine Mfg Support Forum Host
