bad vibration
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> bad vibration
Page: [1]
Login
bad vibration - 6/14/2007 4:15:09 PM
minitman
Status: offline
My honey bee fp seems to wobble around on the floor then go into the air and wobble tip over into the ground...how do i fix this?
       Post #: 1
RE: bad vibration - 6/15/2007 5:27:33 AM
mrasmm
Status: offline
you might just need to give it some more throttle and get it up in the air. If it still wobbles real bad in the air you're gona need to balance it and check to see that the main shaft is straight.
_____________________________
I don't always check every thread I respond to, so feel free to PM me
(in reply to minitman)
       Post #: 2
RE: bad vibration - 6/15/2007 5:38:23 AM
DriveWRX
Status: offline
Another thing you might want to check that each blade is the same tightness to the rotor head. I notice My HBFP will have a bad wobble when the "tightness" is not matched. I like to run my blades on the tight side, others like loose. Either case make sure it's equal.
(in reply to mrasmm)
       Post #: 3
RE: bad vibration - 6/15/2007 6:16:20 AM
Whirley Bird
Status: offline
Like DriveWRX
says keep the blades a bit on the snug side but a wobble while it's in flight tells me something is way DriveWRX
out of wac.
Make sure the pitch on both blades are the same.
The padless should be just as level as you can get them.
Check the distance fron the head to the metal grip on the paddles.
They should be exact as you can get them.
When you have a wobble while in flight you can be sure it's one of the parts that spin fast
Vegas/ http://www.dream-models.com/eco/flying-index.html
Vegas/
The only Easy Day Was Yesterday.
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.266RCU1
