geneh-RCU
AL, USA Status: offline
I am thinking about getting the 80inch Cap232 ARF, and I would like some opinions about it and about the other things ive got to say. The Cap that I am going to buy is technically "not used" but has been purchased and put together by someone else, (a friend of mine). He has built the airplane and has done an "OK" job. He went ahead and drilled the motor holes for the motor but they are off center quite a bit! He drilled the motor holes for a BME44 but like I said was way off. Depending on how far off it is I can fix it but what I want to know is if the airplane is put together poorly, such as not glued that great and the motor puts off alot of vibration when running would it beable to shake the airplane apart? I know that the wing and whatever would fall off because of not being glued together and stuff but is this airplane built well enough that it can stand the vibration of the motor well enough to not start to crack the wood in the wings? I have seen where a motor at idle, will make the wood in the wing crack. I have heard really good things about this airplane but I would like a few more opinions before I go ahead and buy this airplane. (By the way this airplane is $275 from the guy im buying it from). ---------------------------------------------------------------------------------- Theres an Experation date for every airplane, it just doesnt show it!
