no idle and dies at WOT
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> no idle and dies at WOT
Page: [1]
Login
no idle and dies at WOT - 6/16/2007 6:50:05 AM
zx636rider03
Status: offline
i just bought a kyosho subaru with a gxr .28 engine and im having problems getting it idling and when it actually does idle for a few seconds and open the throttle up it dies immediately. the shop that i bought the car from tuned it once but when i got it back to my house it ran for a little then died and began doing what its doing now. for some reason it didnt come with a manual so i have no clue what the factory carb settings are and was told from the guy at the shop that the low speed screw is 5 out and 1 in and the high speed is 3 out and the idle screw is 1-1.5mm. does this sound about right? the only way i can get the thing running is by pouring fuel into the carb which i assume is the reason that it only runs for like 7 sec. for some reason im thinking the fuel is making its way into the engine.. any one have any thoughts. thanks
       Post #: 1
RE: no idle and dies at WOT - 6/16/2007 8:18:24 AM
kevin_kaya
Status: offline
Well, I THINK the idle screw is supposed to be 1-1.5mm when Brakes are applied.
(in reply to zx636rider03)
       Post #: 2
RE: no idle and dies at WOT - 6/16/2007 9:31:02 PM
xxpaRkerxx23
From: Hamnish, LeominsterHerefordshire, UNITED KINGDOM
Status: offline
m8 I am having the same problem!!!
(in reply to kevin_kaya)
       Post #: 3
RE: no idle and dies at WOT - 6/19/2007 2:41:27 PM
drive.hard-go.pro
Status: offline
i think that you should richen it up.... thats why it dies at WOT
_____________________________
if you aint driving your way, you are driving the wrong way
(in reply to xxpaRkerxx23)
       Post #: 4
RE: no idle and dies at WOT - 6/19/2007 3:33:23 PM
joeseif
Status: offline
Is your engine sealed up well? you might have a air leak, but Drive.hard's comment should be tried 1st, it is most likly. Also if the clutch spring is bad that can make it die when you hit the brakes or idle. make sure you have the idle screw set so the carb remains about 2mm or the thickness of a credit card open.
(in reply to drive.hard-go.pro)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.359RCU5
