Fubar-One
Joined: 3/1/2003 From: Canyon Country, CA, USA Status: offline
[QUOTE]Originally posted by KE4UVQ Actually, two and four, had to go look. Engine vibration affected the video transmitter oddly enough, Ive got an OS 46FX with a MACS muffler, a little overkill cause its turning 13k. After reviewing one of Cyberflyer's early videos, he suffered horrible lines in the downlink, said it was vibration, he had the same camera and video xmitter I do now. Some foam corrected it. Now though, when making a hard bank, air pushes on the camera's face and tries to turn it, drove the camera operator nuts so I try to make more rudder assisted turns instead of yanking and banking! [/QUOTE] Have you actually gotten some video using this system yet? I purchased the same pan/tilt setup from Servo City to use with a similar 900mhz system I bought from SuperCircuits. Using my 9C I put the pan on channel 7 and the tilt on channel 8 using the variable slider switchs on the sides of the 9C. Neat feature is the center "beep" so you know where center is without looking at the tx. It seemed to me, tho, that the setup was going to be a bit spindly and suffer from vibration a LOT not to mention wind resistance. My mounting setup is similar to yours but mine is installed in the wing next to the fuse on my Kadet Sr ARF. Anyway, how did the video turn out?
_____________________________
"B Positive to ground, over..."
