Tools for building and repairing t-rex
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> T-Rex heli >> Tools for building and repairing t-rex
Page: [1]
Login
Tools for building and repairing t-rex - 6/16/2007 2:08:47 PM
atcspaul
Status: offline
thought this would be a nice thread since a lot of us are just starting and tools are always needed or tools that just make life a little easier in the heli world. i will keep updating the posts as you all add them.
1. good set of screwdrivers and hex heads
2. ball link pliers
3. blade balencer
4. pitch gage
5. Align one way bearing removal tool...
6. Needlenosed pliers,
7. soldering iron (40W at least) ,
8.exacto knife,
9.permanent marker
10. digital caliper or swash plate leveller
11. vise grips
12. Losi 1.5mm driver.
13.Titanium drill stock so it wont dull like hardened steel allen wrenches.
14. a digital scale
15. dremel moto-tool with various grinding and cutting bits.
16. Infrared Temperature Gage.
12. 12 pack of cold beverage. (choppersrule a 6 pack just isnt enough sometimes)
13. small extractor to be very useful with a cordless drill. Pulls those little stripped out screws out, no problem.
14. ball link reamer ball link sizing tool
15. locktite/holdtite
< Message edited by atcspaul -- 6/22/2007 1:15:07 AM >
       Post #: 1
RE: Tools for building and repairing t-rex - 6/16/2007 3:06:46 PM
djdavidcp
Status: offline
_____________________________
I Fly, therefore I am....................crazy...
(in reply to atcspaul)
       Post #: 2
RE: Tools for building and repairing t-rex - 6/16/2007 3:39:58 PM
atcspaul
Status: offline
thanks dave added to the list
(in reply to djdavidcp)
       Post #: 3
RE: Tools for building and repairing t-rex - 6/16/2007 5:16:52 PM
ArrowNaughtic
Status: offline
Rogaine with monoxidil............. I keep tearing my hair out
And Needlenosed pliers, a soldering iron (40W at least) , exacto knife, permanent marker and beer
_____________________________________________________________________________________
Of all the things I ever lost........................................... I miss my mind the most!
       Post #: 4
RE: Tools for building and repairing t-rex - 6/17/2007 12:49:37 AM
ct420
Status: offline
Add a digital caliper. And I can't stress enough a GOOD set of hex drivers (especially 1.5mm). That is the single most important one IMO. Trying to get those grub screws out with a crappy allen wrench is for the birds
vice grips also good for removing stripped screws and bolts and other things
(in reply to ArrowNaughtic)
       Post #: 5
RE: Tools for building and repairing t-rex - 6/17/2007 3:57:29 AM
cflight
Status: offline
Guys' a purchase you wont regret is the Losi 1.5mm driver. Titanium drill stock so it wont dull like hardened steel allen wrenches.
(in reply to ct420)
       Post #: 6
RE: Tools for building and repairing t-rex - 6/17/2007 4:54:00 AM
HeliSmith
Status: offline
Can someone give a link to a set of titanium allen wrenches for the three sizes that Trex uses? I have a cheapo set and I keep having to dremel cut wheel a little piece off of them. Which as you know strips the screws too.
Also I would love to have a drill bit set in the same sizes!
HS
http://www.helismith.com
(in reply to cflight)
       Post #: 7
RE: Tools for building and repairing t-rex - 6/17/2007 12:18:30 PM
cflight
Status: offline
Hey HeliSmith, You can get the kit or just the 1.5mm as I did. I too am sick of cutting and filing down allen wrenches as replacement tips for my driver. This Losi driver is the ticket, you can also get just the replacement tip, which I plan to do to replace my current hacked allen wrench in driver handle, as I prefer the round handle to the Losi handle. Figures, they've got a great tip and awkward handle.
http://www.horizonhobby.com/Search/Default.aspx?SearchTerm=Losi&CatId=F
(in reply to HeliSmith)
       Post #: 8
RE: Tools for building and repairing t-rex - 6/17/2007 2:10:22 PM
Tolla
Status: offline
There is a swash plate leveller made by Trueblood engineering and distributed by Ready heli.com
This is a exceptionally good idea as it allows you to level the swash plate 100%. .
Have a look at Trueblood engineering.com and follow his instructions as to the use of the tool.
I tried using my digital caliper to level the swash plate and it's not nearly as effective as the swash platre leveller.
Wityh my swashplate 100% level I do not need any other trim and my heli hover dead leve. If there is a tendency to drift then I know to look elsewhere for the problem.
I find that the shape and size of the original leatherman tool is perfect for modelling
       Post #: 9
RE: Tools for building and repairing t-rex - 6/17/2007 6:21:35 PM
atcspaul
Status: offline
all added. put the digital caliper and swash plate level togather
< Message edited by atcspaul -- 6/17/2007 6:22:19 PM >
(in reply to Tolla)
       Post #: 10
RE: Tools for building and repairing t-rex - 6/17/2007 6:50:20 PM
djdavidcp
Status: offline
Don't forget a metric crescent wrench..... LOL!!!!!
       Post #: 11
RE: Tools for building and repairing t-rex - 6/17/2007 7:48:37 PM
ndoren
Status: offline
Two things I've found handy... a digital scale and a dremel moto-tool with various grinding and cutting bits.
       Post #: 12
RE: Tools for building and repairing t-rex - 6/17/2007 9:29:19 PM
choppersrule
Status: offline
Hi guys, Chopper Here:
Another good gadget, but not needed for building / re-build or repairing. Is an Infrared Temperature Gage.
Take temperatures of each component after each flight and it can give you a heads up on something failing.
Stuff I monitor, main motor, (tail motor on the Blades), battery, ESC's, heat sinks. And anything else you may want to monitor.
Lots of oil , I lube almost everything that moves, however, don't use oil on any rubber parts. Use a teflon/silicon based spray. Oil, has a tendency to soften rubber and will deteriate over time.
Oh, and a six pack of your favorite beverage.
Dave / Choppersrule
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by choppersrule -- 6/17/2007 9:34:32 PM >
Left skid low....
       Post #: 13
RE: Tools for building and repairing t-rex - 6/18/2007 6:36:30 PM
Tolla
Status: offline
That's pretty much what my toolbox contains. Never used a vice grip or dremel tool, though.
       Post #: 14
RE: Tools for building and repairing t-rex - 6/18/2007 11:10:19 PM
pt40crasher
Status: offline
http://www.sears.com/sr/javasr/product.do?cat=Mechanics+Tools&pid=00952155000&vertical=TOOL&subcat=Taps+%26+Dies&BV_UseBVCookie=Yes
I have found the small extractor to be very useful with a cordless drill. Pulls those little stripped out ****s out, no problem.
(in reply to Tolla)
       Post #: 15
RE: Tools for building and repairing t-rex - 6/19/2007 4:19:10 PM
DougV
Status: online
At times lots of PATIENCE!
(in reply to pt40crasher)
       Post #: 16
RE: Tools for building and repairing t-rex - 6/19/2007 4:41:26 PM
