Anthoop
Joined: 2/3/2007 From: , UNITED KINGDOM Status: offline
quote:
ORIGINAL: lsurber Once you have crank position locked for your new timing marks measure depth from top of sleeve to top of piston. Next, transfer the inside measurement to the outside of the sleeve, mark with scribe, and start cutting! I see where your coming from and yes if the top of your port was square that's an accurate method.However i think the profile of the port should direct gases with minimal airflow disruption,invariably meaning the inside edge of the port will be the opening point(highest)and the outer will be lower(measured from top deck/piton crown@tdc). I think the method that SavageJim has posted above(edge tape up cylinder with piston using d.wheel)is an excellent method,just ensure the sleeve is totally grease free and press the tape down firmly so it wont move then re-check quote:
ORIGINAL: lsurber For crank induction, remove the carb, turn crank to new open/close timing and scribe a line on the crank. Remove crank, cut, polish edges, reassemble, and go run! Works for me! I agree can't go wrong with that
_____________________________
When I die, I want to go in my sleep like my grandfather,not screaming like the passengers in his car at the time.
