RE: Are you Yakkin' ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Are you Yakkin' ?
Page: <<   < prev  7 8 9 10 11 12 13 [14] 15 16   next >   >>
Login
RE: Are you Yakkin' ? - 3/14/2008 12:09:41 AM
Taildragger726
Status: offline
Looks great MIX !!!! How about a flight report ???
_____________________________
Also known as N726AC
       Post #: 326
RE: Are you Yakkin' ? - 3/14/2008 12:43:56 AM
FLYMIKE
Status: offline
My EF Yak 74" with Evo 45cc.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by FLYMIKE -- 4/7/2008 2:14:58 AM >
(in reply to Taildragger726)
       Post #: 327
RE: Are you Yakkin' ? - 3/14/2008 12:59:32 AM
OldRookie
Status: offline
Absolut Yak,
What exactly is HUCKING?
I have seen this term used before, but don't know what it means.
Greg
LiFe is Great
(in reply to Absolut Yak)
       Post #: 328
RE: Are you Yakkin' ? - 3/14/2008 1:47:19 AM
Taildragger726
Status: offline
Doug,, if I may?
Huck; To fly a plane or helicopter in a manner that is low to the deck in 3D attitude. Also referred to as Hucking
Hucker; One who Hucks.
Huckaholic; A person who has difficulty remaining more than 3 times the wingspan of the plane, above the ground for extended periods of time. Exceptions are made for Blenders, Waterfalls, KE Spins, Parachutes, Roller-Coasters and similar moves. These should all end at about 10 feet above ground. Example, a 102" yak should not be flown in a lame manner at an altitude exceeding 306" for extended period of time.
Shamelessly borrowed from FG's
< Message edited by Taildragger726 -- 3/14/2008 1:51:55 AM >
(in reply to OldRookie)
       Post #: 329
RE: Are you Yakkin' ? - 3/14/2008 3:02:32 AM
wifpwcf
Status: offline
quote:
ORIGINAL: Taildragger726
Doug,, if I may?
thats hucking right there..i try get a 3mtr plane 1.5mtr of he deck in rollers pucker factor 101% lol.
i find it hard to fly imac as i love the rush 3D gives me ,,thats not a crime is it
cg
TEAM AUSTARS,TEAM TO MUCH FUN CLUB
TEAM BIG COURAGE DIAMONDS
       Post #: 330
RE: Are you Yakkin' ? - 3/14/2008 4:27:31 AM
Flyin Hawaiian
Status: offline
3D is the essence of the adrenaline rush. In theory, to 3D, Freestyle, and "down in the dirt with grass stains" Huckin' is what defines me, in other words,........." I 3D, therfore, I am!"
< Message edited by Flyin Hawaiian -- 3/14/2008 4:28:09 AM >
Rennie "Fly Low & Slow & In Control!"
Team Extreme of extremeflightrc.com / B & E Graphix
(in reply to wifpwcf)
       Post #: 331
RE: Are you Yakkin' ? - 3/14/2008 1:49:35 PM
Absolut Yak
Status: offline
Doug,, if I may?
What he said!
Doug
Stand Back! I'm Fixin' to Yak!
       Post #: 332
RE: Are you Yakkin' ? - 3/14/2008 2:18:09 PM
MIXMASTER
Status: offline
Actually coming in contact with the ground, deliberately, & flying off without a scratch, the apex of Huck'in. The ground is the limit!
Will absolutely return a flight report for my Extreme TOC Yak, good , bad or indifferent.
Jimmy touch tail & I dont care!!!
       Post #: 333
RE: Are you Yakkin' ? - 3/21/2008 1:54:25 PM
wifpwcf
Status: offline
I LOVE MY YAK
http://au.youtube.com/watch?v=mqWSIrDl0w0
(in reply to MIXMASTER)
       Post #: 334
RE: Are you Yakkin' ? - 3/21/2008 6:46:55 PM
OldRookie
Status: offline
Now that is HUCKIN!
Greg
LiFe is Great
       Post #: 335
RE: Are you Yakkin' ? - 4/6/2008 5:00:40 PM
overpower
Status: offline
http://youtube.com/watch?v=jk8XNhBA8y4
http://youtube.com/watch?v=m5Bl6sim3mo&feature=related
Trust me the second one isnt a yak but its worth your time ignore the first 10 seconds
(in reply to Tor)
       Post #: 336
RE: Are you Yakkin' ? - 4/7/2008 12:07:41 AM
Absolut Yak
Status: offline
My motor puked on me today. Thankfully not until I was on the ground and tried to restart. Clanking and low compression and would only briefly fire. Off to DA, after 300 + hard 3D flights. Plane has been flying GREAT. The time on the flight sim has been paying off.
Doug
(in reply to overpower)
       Post #: 337
RE: Are you Yakkin' ? - 4/7/2008 4:56:01 PM
MIXMASTER
Status: offline
My Extreme TOC Yak is (30%) 16.6 lbs. with a spinner. Had to put it on, still a bit tail heavy (CG 7.5" 6.5 is the recommended. I used the 3" standoffs & have the ignition battery on the firewall. The receiver batt is at the cowl ring, at the top of the cannister tunnel. I tried to keep rcv batt 12" away from ign , but ended up around 6" at best. Is this less critical with the 2.4FASST systems? I will definately do a running range test, which I normally do anyway.
       Post #: 338
RE: Are you Yakkin' ? - 4/7/2008 7:11:36 PM
redflyboy122
Status: offline
here are my extreme flight twin yak 54 both the 47" electric and 74" powered by and os160 with hitec hs5985 servos. love em both!! heres a video of the 7th flight of the 74".
http://au.youtube.com/watch?v=N1olZn5Ywe8
Click for fullsize
< Message edited by redflyboy122 -- 4/7/2008 7:14:44 PM >
       Post #: 339
RE: Are you Yakkin' ? - 4/7/2008 7:15:25 PM
redflyboy122
Status: offline
holy crap that uploaded huge. i cant get it smaller for some reason. sorry bout that
(in reply to redflyboy122)
       Post #: 340
RE: Are you Yakkin' ? - 4/7/2008 8:43:24 PM
