RE: Are you Yakkin' ?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> RE: Are you Yakkin' ?
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Are you Yakkin' ? - 7/1/2007 7:10:45 PM
Cryhavoc
Status: offline
Just finished my Aeroworks Yak 54 104" 100cc. Just have to maiden her. Easiest build I ever did. Dual Fromeco 4800's w/deans, Smartfly Power Expander Pro, Fromeco Wolverine & Badger switches, Futaba FP-R149DP, 3W106B2 w/28-10 TBM prop for breakin, Tru-Turn Spinner, Sullivan Skywriter smoke pump, Fromeco 2400 on ignition, Hitec HS5945 all surfaces and throttle, rudder JR DS8711, choke HS 5625 and of course, Kirbys Kustom Graphics.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Cryhavoc -- 7/1/2007 7:13:33 PM >
_____________________________
Cryhavoc! Let slip the dogs of RC!
Can I get a job doing this?
(in reply to Flyjets)
       Post #: 51
RE: Are you Yakkin' ? - 7/2/2007 1:47:05 AM
Richard D Bahmann aka/Wrongway
Status: offline
Nice looking plane. It should go pretty good with that 106 and smoke. Maybe a video after a while?
R
To go where no man has gone before...without government permission. In 1938 Wrong Way Corrigan becomes an American Hero.
(in reply to Cryhavoc)
       Post #: 52
RE: Are you Yakkin' ? - 7/3/2007 4:36:40 AM
Rush7
Status: offline
Well it looks like I am going to jump in here with you guys. My Yak is an old one but I think it is going to be a good one. I found this guy hanging in the rafters in a guys shop in Nashville. The tail was put together and that was it. I had to straigten out a few things that were not right but I think I am just about there.
The main problem was getting all of the dirt dobber nest cleaned out of the fuse and wings.
Well from what I can tell it looks like I am fixin to Yak. I always heard that once you go Yak you never go back.
If everything goes well hopefully she will maiden this weekend.
I do have one question for all you guys that have had one of these EF Yaks. It looks like the CG is going to be at about 2.25" behind the wing tub, is this going to be okay?
Click for fullsize
Click for fullsize
http://www.crccflyers.org
Huckin'' til it hurts
       Post #: 53
RE: Are you Yakkin' ? - 7/3/2007 4:47:41 AM
GalenB
Status: offline
quote:
ORIGINAL: Rush7
I am not exactly sure where mine is now, but it is very near the recommended CG location and I think that is much farther forward than yours... I have all of my batts up on the motor box, plus a couple oz of lead attached to the stand offs to get the proper CG...
Cheers!
(in reply to Rush7)
       Post #: 54
RE: Are you Yakkin' ? - 7/3/2007 11:30:59 AM
Status: offline
Yeoow Rush, 2 1/4 behind the wing tube? I read every page of the original EF thread and only remember folks saying that they were doing the balance on the little stripe of color, or in that area.
Most aircraft designers design the plane to fly on the wing tube which is the center of the pitch/yaw axis. Some guys like to go behind the wing tube for their style of flying, and I have heard of 1 inch or even 1 1/2 inch.
Maybe if you have an old spinner to throw on just for maiden kicks? Or strap some removable lead up front? Lots of things can happen on a maiden and the last thing you want is to be chasing the stick all around to keep it flying. IMHO
Good luck.
BTW nice plane!!
(in reply to GalenB)
       Post #: 55
RE: Are you Yakkin' ? - 7/3/2007 1:36:28 PM
larshkj
Status: offline
Here's 3 pictures of my 100cc AW Yak.
3W 106CS on cans with a Engel SuperSilence 26x12 3-blade, 5985 on ailerons, 5955 on elevators and rudder. Emocotec Mini 5 and Fromeco 2400 Peerless for power. Flies great!
Edit: Forgot to mention. I have a SD-Models 33% Yak on it's way too. 3W 80Xi with canister, TBM 2600 batteries, Emocotec Mini 5, and the same servo setup as my AW Yak. Plus original SD-model carbon landing gear (looks great by the way!), SD-Model wingbags, carbon wingtube and stabtube.
It should be here this weekend
Lars
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by larshkj -- 7/3/2007 1:49:38 PM >
       Post #: 56
RE: Are you Yakkin' ? - 7/3/2007 2:02:56 PM
torqmeister
Status: offline
Rush, mine balances at 7 3/4" from leading edge at the wing root. At that balance point, it flies absolutely nuetral. Good luck with the maiden. And you're right, once you Yak, there's no going back.
AMA 8051
(in reply to Rush7)
       Post #: 57
RE: Are you Yakkin' ? - 7/3/2007 5:16:55 PM
JoeAirPort
Status: offline
quote:
ORIGINAL: torqmeister
Mine's about 7 1/4 - 7 1/2. Flies great, drops very slowly inverted.
Joe AP
(in reply to torqmeister)
       Post #: 58
RE: Are you Yakkin' ? - 7/3/2007 7:52:42 PM
Rush7
Status: offline
Thanks for the help guys. I will move my batts to the motor box. I also put a 24oz fuel tank on it for kicks and I can t see buring that amount of fuel before landing.
(in reply to JoeAirPort)
       Post #: 59
RE: Are you Yakkin' ? - 7/3/2007 8:46:48 PM
plaster93
Status: offline
Ultra Rc, 107" yak 54, 3w 106 on pefa cans,28x10 mejzlick prop, 2-5955 on the rudder, 5985 elsewhere, 3 fromeco 2600 packs, emcotec mini, JR reciever.
Flys awesome!
Click for fullsize
Click for fullsize
(in reply to Rush7)
       Post #: 60
RE: Are you Yakkin' ? - 7/4/2007 5:27:29 AM
Lormuhl
Status: offline
Here is my two yaks. Aeroworks 100cc with a DA100 and a Aeroworks 90-120 with a SPE26
Click for fullsize
(in reply to Jim Flannigan)
       Post #: 61
RE: Are you Yakkin' ? - 7/4/2007 2:33:31 PM
LearnedInUk
Status: online
Only have one YAK
Click for fullsize
(in reply to Lormuhl)
       Post #: 62
RE: Are you Yakkin' ? - 7/5/2007 6:18:06 PM
Taildragger726
Status: offline
The color scheme does not reflect lifestyle ,,,but it does show well in the sky!
< Message edited by Taildragger726 -- 7/5/2007 6:19:22 PM >
Also known as N726AC
(in reply to LearnedInUk)
       Post #: 63
RE: Are you Yakkin' ? - 7/7/2007 10:28:20 PM
Status: offline
Nice plane Taildragger. Do they let you use the runway, that is a runway behind you yes?
That would be the setup. Taxi the plane from the garage to the runway....fly....taxi home.
Cool
To go where
