Big feet
Joined: 8/7/2005 From: Carrickfergus, UNITED KINGDOM Status: offline
quote:
ORIGINAL: []TEX[] Can't the Rx run on a 6V battery without a regulator? Hi, I think (but not totally sure) that Futuba can handle 6v, while JR need to run at 4.8v. That is from a far and distant memory so if anyone has more up to date info, please correct me. quote:
If I understand BH correctly is he saying it slowing the collective/throttle response time? No, you want to set the throttle end points around 70-80. The servo will get to the end point quicker that the collective servo which you set to 110-120 end points. This way the throttle is always ahead of the pitch demand and so keeps the RPM from slowing down as much. What I think BH is saying is that he was unable to run these settings with the PP system, so he elected to go with the single pushrod system. I am using PP on my Titan and have been able to set mine up like this and the throttle does stay ahead of the pitch servo. I have not done anything to prevent fuel getting into my tail servo. If anyone has a method of sealing it please post it. Cheers
_____________________________
Please remember, RC is dangerous to your wealth
