RE: Raptor 50 Titan Discussion
Tower Hobbies
Logged in as Guest
  Printable Version
E-Flite Blade CP Pro - RTF
Seller:  hhager2
Details:   $500.00   |  11/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Thunder Tiger - Raptor 30, 50, 60, 90 >> RE: Raptor 50 Titan Discussion
Page: <<   < prev  1 2 [3] 4 5 6 7 8 9 10   next >   >>
Login
RE: Raptor 50 Titan Discussion - 6/21/2007 4:31:19 AM
GravityWorks
Status: offline
thank you tex for your help, it is appreciated. what do you think of my titan... pretty sweet huh?
(in reply to []TEX[])
       Post #: 51
RE: Raptor 50 Titan Discussion - 6/21/2007 11:20:26 PM
[]TEX[]
Status: offline
quote:
ORIGINAL: GravityWorks
Ya, that thing is pretty crazy. Did it come with the motor and ESC?
_____________________________
JR Vibe 50 powered by O.S. | 7C FASST | Hatori Perfomance | Curtis Youngblood | Reactor X | CSM RL20 | Let the fun begin!
(in reply to GravityWorks)
       Post #: 52
RE: Raptor 50 Titan Discussion - 6/23/2007 2:10:51 AM
heli junky
Status: offline
Heres a couple of pictures of my Titan
Enjoy
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 53
RE: Raptor 50 Titan Discussion - 6/23/2007 3:02:32 AM
[]TEX[]
Status: offline
What is the best way to tune the motor on this heli? Run it with out the mains?
(in reply to heli junky)
       Post #: 54
RE: Raptor 50 Titan Discussion - 6/23/2007 5:51:33 AM
GravityWorks
Status: offline
thats a sweet titan man. And no my heli did not come with a motor or ESC, I went with a Z-Power Z50A-800 780Kv and a Pheonix 85HV speed controller, with an 8 cell lipo, this motor turnes 4000 kilowatts approx 5 horse power (I think) It has alot of power to burn anyway.
Anyway I love your color sceam I think its cool when people keep it the same throughout the bird. as apposed to blue fins purple bolts and a red canopy... you get the idea.
       Post #: 55
RE: Raptor 50 Titan Discussion - 6/23/2007 2:14:08 PM
USMC2111
Status: offline
No, DO NOT run the helicopter without the main blades. For Engine tuning visit raptor technique.
http://www.raptortechnique.com/enginetuning_beginner.htm
Except for ending Slavery, Fascism, Nazism, and Communism, WAR has never solved anything.
       Post #: 56
RE: Raptor 50 Titan Discussion - 6/23/2007 4:49:01 PM
helimedic
Status: offline
Hey Heli Junky
SWEET paint!!!!
Raptor Titan 50, OS 50SX Hyper, Futaba 9252, JR G500T/8700, XP9303..."Propofol"...Got Milk?
(in reply to USMC2111)
       Post #: 57
RE: Raptor 50 Titan Discussion - 6/23/2007 5:00:46 PM
[]TEX[]
Status: offline
quote:
ORIGINAL: USMC2111
THANK YOU!
       Post #: 58
RE: Raptor 50 Titan Discussion - 6/23/2007 11:06:36 PM
heli junky
Status: offline
Thanks helimedic, And Its not as hard to track as I thought it was going to be.
       Post #: 59
RE: Raptor 50 Titan Discussion - 6/24/2007 1:07:04 AM
helimedic
Status: offline
Really?! That's cool, I thought it would have blended in, go figure. Mine still has the polypropylene bleach bottle look
       Post #: 60
RE: Raptor 50 Titan Discussion - 6/24/2007 1:15:40 AM
helimedic
Status: offline
Question. With my servos, the Titan came with metal plates that go over the grommets. Should I use these alone, with the brass eyelets that come with the servos or just the brass eyelets? My R30 did not come with these plates so I just had the brass eyelets.
(in reply to helimedic)
       Post #: 61
RE: Raptor 50 Titan Discussion - 6/24/2007 1:23:21 AM
helimedic
Status: offline
Nevermind, I found the answer on RR. Thanks Hockey.
       Post #: 62
RE: Raptor 50 Titan Discussion - 6/24/2007 1:27:14 AM
[]TEX[]
Status: offline
I have set up all my pitch curves and getting ready for the first flights tomorrow AM.
Are you guys using the DS on your 401's or not? I heard that the 401 in DS mode has been burning up servos. Yes, I am using digis.
       Post #: 63
RE: Raptor 50 Titan Discussion - 6/24/2007 1:37:46 AM
BarracudaHockey
Status: offline
ds mode doesn't burn up servos, running too much gain does.
Yes do DS mode.
Don't crank it all the way up till it wags then back off, start with 50 percent and go from there, if it holds leave it alone.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
       Post #: 64
RE: Raptor 50 Titan Discussion - 6/24/2007 2:28:22 AM
[]TEX[]
Status: offline
quote:
ORIGINAL: BarracudaHockey
Yes do DS mode.
OK, right now I have this set for my 401
Normal mode A80%
Idle 1 A70%
Idle 2 N70%
Do you agree or disagree with these settings?
I also adjusted the limit to about 85-90% and delay is factory setting at 75%
< Message edited by []TEX[] -- 6/24/2007 2:32:40 AM >
(in reply to BarracudaHockey)
       Post #: 65
RE: Raptor 50 Titan Discussion - 6/24/2007 3:32:42 AM
USMC2111
Status: offline
I didnt see anywhere where you stated what servo you are using with the 401 gyro. Are you using the 9254? If so, you need to set the delay to 0, and the DS switch to on. If you are not using a digital servo on the tail, turn the DS to off and add a little delay. The 401 gyro was designed around the 9254 servo, so it is the perfect match. Therefor, does not need any delay. Delay is mostly used for non digital servo's.
Here is a link to better help you understand.
http://www.futaba-rc.com/team/team-tip-002.html
