Jackster00
Joined: 3/8/2003 From: Caledonia, IL, USA Status: offline
Jeff: If you REALLY want a small one, and lots of fun, get a Herr Cloud Ranger. I'll tell you, it's an .049-.061 size, but I've put a .15 Thundertiger on it and it is a real handful! I chose the Cloud Ranger because you get ailerons. The others I've seen that size don't have them. Sure, it's flat-bottom wing and all, but it'll do a snap roll better than anything I've had, in fact, you'll have to work to keep it to a single snap! Evidently, the airframe and wing stand up to the .15 engine, as I've never had a structural failure of any kind. You'll have to experiment with different size wire landing gear to suit your landing abilities, as it's real bouncy and touchy on landing, and the tailwheel mounting and the elevator half connections need to be beefed up, but it's a very fast building little aircraft. Everything is inexpensive on this plane, and if you lose it, shucks, just build another one for cheap. I love mine. Jackster
