camdyson
Joined: 7/20/2005 From: Bairnsdale, AUSTRALIA Status: offline
Hi Steve, YIKES!! I hate to be a killjoy, but I'd start by cutting ALL your existing elevator horns off flush, and start again (rebuilding the result of a crash takes alot longer... ) You need to use quality aircraft ply, or better yet carbon, steel or circuit board as Don says. you can restore the "old" look to these materials by addind a veneer of 1mm ply on the outsides. I'd be inclined to cut back the covering around the existing horns and check what you're gluing to, then patch around the new horns, hiding the old stumps at the same time. Oh, shim them parrallel to the clevis too! Man, you must have the patience of a saint with this thing! Cheers, Cam
