To Gyro or not to Gyro?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Jets >> To Gyro or not to Gyro?
Page: [1] 2 3 4   next >   >>
Login
To Gyro or not to Gyro? - 6/18/2007 3:37 AM
SinCityJets
Score: 115
Last Login: 5/17/2013
Status: offline
OK, I have seen and read a lot of stuff about gyros, and have used them before in helis. You can't run one in giant scale gassers, because you get called a cheater (3D).
So, when it comes to turbines, are people using them mainly for nose wheels, or nose and rudder?? what??
Can you get away with using a cheap piezo, or are you better off going with at least a Futaba 401?
As always I appreciate your input and am not looking for this to turn in to a brand war.
Hide Signatures
       Post #: 1
RE: To Gyro or not to Gyro? - 6/18/2007 4:05 AM
Edgar Perez
Score: 100
Last Login: 5/19/2013
Status: offline
I use it only for nose wheel steering. A cheap one is fine.
One day I will try a dual output for aileron.
In jets, it's not cheating if it makes you look good
_____________________________
Edgar Perez
Puerto Rico
Hide Signatures
(in reply to SinCityJets)
       Post #: 2
RE: To Gyro or not to Gyro? - 6/18/2007 9:34 AM
SinCityJets
Score: 115
Status: offline
come on guys (and gals), all suggestions appreciated.
Hide Signatures
(in reply to Edgar Perez)
       Post #: 3
RE: To Gyro or not to Gyro? - 6/18/2007 10:34 AM
martinan
Score: 100
Last Login: 5/13/2013
Status: offline
C2,
I think most guys won't admit that they use gyros so the responses might be a little weak (LOL).
I use a JR 500A on my nose wheel only and it gives my servo a big time work out. I have it installed close to my ECU so
everytime I start the turbine it picks up on the RF from the ECU and then it really gives the servo a workout. The neat thing about it is that I can
adjust the sensitivity from a spare channel and I usually turn it down during startup and then turn it back up again when I'm taxing out to the runway.
It works really great to keep the airplane tracking straight.
Good luck with the aileron setup.
Hide Signatures
       Post #: 4
RE: To Gyro or not to Gyro? - 6/18/2007 11:42 AM
Koenieboy
Score: 100
Status: offline
I've never flown with gyro's. I find jets flying quite stable from themselfs (just program enough expo )
But people asked already 2 times which gyro I'm using: My answer is "the one between my ears"
Hide Signatures
(in reply to martinan)
       Post #: 5
RE: To Gyro or not to Gyro? - 6/18/2007 11:56 AM
JET FX
Score: 105
Last Login: 2/25/2013
Status: offline
Gyros are for 'girls' right...?
< Message edited by Jet FX -- 6/18/2007 12:10 PM >
MARTY COWAN CEO
JET FX ~ JETS & WARBIRDS
Hide Signatures
       Post #: 6
RE: To Gyro or not to Gyro? - 6/18/2007 1:30 PM
Geoff White
Score: 100
Status: online
Its fairly common to see gyros on nosewheel steering as it helps keep it straight on takeoff.
It is also common to see them on the rudder of swept wing jets, F86's and Mig 15's for example. The reason why is that swept wing jets have a slight tendency for yaw instability, its only slight but noticable. Aerodynamically, I have no idea why but I am sure someone will enlighten us.
At several european meets and WJM events I watched some of the top european flyers and was well impressed at the solidity of the flight. After discussing this with friends, I was told that its because they nearly always use a gyro on the ailerons. So while many people may say 'I don't need a gyro on my ailerons', I say try it and then make up your mind.
Hide Signatures
(in reply to JET FX)
       Post #: 7
RE: To Gyro or not to Gyro? - 6/18/2007 2:09 PM
extra 300
Score: 100
Last Login: 5/18/2013
Status: offline
Any idea on type of gyro to use on ailerons?
Thanks for your help.
Dany
Hide Signatures
(in reply to Geoff White)
       Post #: 8
RE: To Gyro or not to Gyro? - 6/18/2007 2:49 PM
Jgwright
Score: 101
Status: offline
The most popular Gyro for use on ailerons is the ACT Fuzzy Pro from Germany.
http://www.acteurope.de/html/fuzzy_pro_v2.html
There is an English transation of the manual available. I have 3 of their Gyros on 3 planes operating on ailerons. It helps models particularly, with smaller wingspans to hold a solid presence in the air. These gyros have variable gain so it can be adjusted during the flight.
John
John Wright
Hide Signatures
(in reply to extra 300)
       Post #: 9
RE: To Gyro or not to Gyro? - 6/18/2007 2:55 PM
Geoff White
Score: 100
Status: online
I am told Futaba also make a gyro that is specifically designed for fixed wing but I have no experience of it.
Me, personally, I have an ACT fuzzy logic V2 gyro that is going to be installed in my Hawk very soon.
Geoff.
Hide Signatures
(in reply to Jgwright)
       Post #: 10
RE: To Gyro or not to Gyro? - 6/18/2007 2:59 PM
JET FX
Score: 105
Status: offline
quote:
ORIGINAL: Geoff White
I have both Mig-15 and F-86 (Fiber Classics) and they fly as easy as any scale aircraft I have ever flown to be honest 'without' gyros fitted.... so much for that argument! also using expo on your steering takes care of any undo sensitivity on the nose wheel.
The one model I have flown where a gyro maybe?? of been of some use to my nerves was when landing a rather nose heavy 1/8 scale Chinese ARF F-18 without using any flap, a much higher than anticipated roll out speed being necessary but even that proved uneventful, more concern really about tyres blowing off the rims.....
MARTY COWAN CEO
Hide Signatures
       Post #: 11
RE: To Gyro or not to Gyro? - 6/18/2007 3:04 PM
Boomerang1
Score: 120
Status: offline
I fly just a basic jet & it's easy to handle so I can see no point of a gyro in this model.
But if I had a beast to tame why not? - John.
Distributor for: Nothing! So my posts can be unbiased.
Hide Signatures
       Post #: 12
RE: To Gyro or not to Gyro? - 6/18/2007 3:07 PM
Geoff White
Score: 100
Status: online
Well as I said swept wing jets fly fine without a gyro but they can be improved wth a gyro on the rudder.
In addition here is a direct cut/paste from bvms website
"GYRO's
Some new and old information
BVM likes the advantages of using a Piezo Electric Gyro on the yaw axis of our jets. Practically any jet's in-flight stability and ground handling are enhanced with the proper application of these high tech devices"
Its a matter of personal choice.
Hide Signatures
       Post #: 13
RE: To Gyro or not to Gyro? - 6/18/2007 3:16 PM
JET FX
Score: 105
Status: offline
"GYRO's
Yeah well we all know BV cant fly!.... Maybe it has to do with flying upside down and using mode 1 (an Aussie thing)
Hey that reminds me a line from a certain movie, can you guess-
"There's no reason to become alarmed, and we hope you'll enjoy the rest of your flight. By the way, is there anyone on board who knows how to fly a plane?"
MARTY COWAN CEO
Hide Signatures
       Post #: 14
RE: To Gyro or not to Gyro? - 6/18/2007 5:24 PM
SinCityJets
Score: 115
Status: offline
Airplane!
Hide Signatures
       Post #: 15
RE: To Gyro or not to Gyro? - 6/18/2007 6:39 PM
Tom Antlfinger
Score: 101
Status: offline
I have never found a gyro necessary for nose wheel steering.....as mentioned, having 3 rates and expo settings on the rudder hi/mid/low rate switch on my 10X solves those problems....
I am now flying the 80" BVM F-86.......the only time I turn on the rudder gyro (Aux 2, 3-position switch using gyro gain menu 44) is when I am landing or flying on a X-Windy day......the Saber lands without dutch roll on relatively calm days, but will start dutch rolling with a stiff cross wind and my dumb thumbs in the typical PIO mode....up in the air, the gyro will damp any unsightly tail waggle on windy, bumpy days.....I use about 1/2 gain in the air vs landing....
I have a Wingo on my SJ F-16 tailerons and like it....but I am out of channels on my Saber, so haven't tried it........
I have a JR 500A in the Saber, using an 8611 for the rudder servo.....
Tom
Hide Signatures
       Post #: 16
RE: To Gyro or not to Gyro? - 6/18/2007 7:59 PM
ravill
Score: 125
Status: offline
I use JR 410 on the nose of every jet I own. I will never own a jet without one.
I tried this same gyro on the ailerons of my F-18c, and found it to be a little scary in flight. I put the gain right on half way (no way to adjust from transmitter, ) and the airplane was hunting in the sky. Very alarming. I landed and yanked the gyro right out of there. I had no idea where to place the intial gain settings so I guessed and did not like it.
I'd love to try a gyro on the ailerons, I've heard that Ali uses one. If he can use one, than why can't I?
Raf
RAVjets Demo team. All We Do Is Fly.
Hide Signatures
(in reply to Tom Antlfinger)
       Post #: 17
RE: To Gyro or not to Gyro? - 10/4/2007 3:35 AM
JeanLucPicard
Score: 100
Last Login: 9/18/2008
Status: offline
could you folk kindly link me up to gyro research pages
I am wondering if there are such things as gyros which can hold wings steady in buffety conditions on the smaller aircraft to provide scale appearance
a) no stick input
b) stick applied at say 25% deflection and held and bank angle then held with appropriate mixed elevator and rudder intermixed?! (need speed and v accurate height inputs to accomplish?) - ie childs play scale turns with aileron stick moved and held like a steering wheel on a car - if balanced steady turns can be accomplished, pitch and speed should be easy enough to manage
This is for an amateur pilot flying scale 3 to 8 ft models and not wishing to perform stunt flying. - rudder can still be operated manually for controlling x-wind take off / landing etc, and set to either intermix with gyro controlled ailerons or indipendent
I really dont like to see scale aircaft tossed around like a toy if aileron gyros are responsive enough to hol the roll steady at all times - rock steady landing on flaps at low speed with rock steady wings would be very satisfying ('cheating' or not..)
Hide Signatures
       Post #: 18
RE: To Gyro or not to Gyro? - 10/4/2007 5:16 AM
Likai
Score: 100
Status: offline
Recently, an experiment what I want to do is moving CG far backward to make the plane aerodynamically unstable( like many modern fly-by-wire jet fighters) and in such case gyro controlled pitch/yaw is the only way to keep the plane flying. I have tried this idea in RealFlight G3 simulator, when elevator and rudder controlled by gyros I can move CG approx 200mm backward in a 3 meter long plane and this plane can make many unbelievable maneuver.
Li, Kai
Engineer of Skymaster
Hide Signatures
(in reply to JeanLucPicard)
       Post #: 19
RE: To Gyro or not to Gyro? - 10/4/2007 12:05 PM
Jgwright
Score: 101
Status: offline
JeanLuc
If you look at this video you can see my Swallow flying with gyro on ailerons. The only time that there is any waggling of the wings is when Dave was trying to free the nose leg for landing. The rest of the time it is smooth as silk. It is a nice stable plane though which helps. Most of the early flying was done with the gyro set at about 50% but recently we have been experimenting in turning it down in flight using the variable gain to about 25%. This helps make the rolls a little less 'notchy'. The best gyros I have found are from ACT in Germany. http://www.acteshop.de/product_info.php?products_id=2040
Likai
We have flown a number of planes with gyros on ailerons and it definitely saved one model on its first flight when the CG was too far back. I cannot say whether it would aid manouvers as we were just so pleased to get the plane to land and correct the CG. If you want amazing manouvers then vectored thrust seems the way to go.
John
John Wright
Hide Signatures
(in reply to Likai)
       Post #: 20
RE: To Gyro or not to Gyro? - 10/4/2007 12:16 PM
djindivik
Score: 100
Last Login: 7/8/2011
Status: offline
It's probably not "cheating", as such, but it's a bit "girly", in my Humble opinion. Mmmm, That should stir up a hornets nest ! Ray.
"JETS"- Who dares-Grins !
Hide Signatures
       Post #: 21
RE: To Gyro or not to Gyro? - 10/4/2007 1:30 PM
JET FX
Score: 105
Status: offline
Reckon they could be the go for use in conjunction of inflight thrust vectoring and lateral exhaust deflection/ rudder mixing... otherwise most definetely probably a little "girly". I still cant understand why using expotentional on your steering is not enough??? and on ailerons hmmmmm.
Hey does that mean the WJM should maybe now referred to as the WGM
MARTY COWAN CEO
Hide Signatures
(in reply to djindivik)
       Post #: 22
RE: To Gyro or not to Gyro? - 10/4/2007 5:05 PM
JeanLucPicard
Score: 100
Status: offline
Hi JG
Thanks for reply, yes most tips appear to head toward ACT - some Futaba
Unfortunately couldnt find your 'demo' link
I would be interested in receiving links to any reviews / demos of gyros being switched on / off on twitchy roll set up to convince me it would be worthwhile at the other extreme end to Jets - scale high wing Cessnas! (albeit ones very highly loaded requiring some degree of flap for general flying at scale speeds)
Incidentally what on Earth happens during a spin - presumably manual input of rudder and forward stick would overcome ailerons going crazy?!
Hide Signatures
       Post #: 23
RE: To Gyro or not to Gyro? - 10/4/2007 5:54 PM
Jgwright
Score: 101
Status: offline
Sorry something went wrong there
http://youtube.com/watch?v=2qra_7YjoYw
Try this
John
John Wright
Hide Signatures
       Post #: 24
RE: To Gyro or not to Gyro? - 10/5/2007 12:52 AM
DelGatoGrande
Score: 105
Status: offline
high speed on the runway.danger.always gyro for take offs and landings
make your self a favor and get a gyro.stering AND rudder! set up on retracts swich.up less gain down more
if gyro is girly and not help i would love to see some "men" fly a jet with no expo!
Best Regards George SKYMASTER-A/D JETS-JETCAT-POWERBOX www.rcjet.gr "props are for boats"
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.313RCU1
