martinh
Joined: 6/30/2002 From: BirminghamWest Midlands, UNITED KINGDOM Status: offline
quote:
ORIGINAL: Rob Howarth Guys, I bought one of these Twisters and was excited to get it in the air yesterday - .............. what a let down. The aircraft is nothing as I would have expected. My set up is a 3s Thunder Tiger 2100 lipo, Hacker X40 ESC, 146i Futaba RX and the servos as recommended. Performance was VERY poor, just about managing a reasonable vertical line from a dive. Hand launch performance also not too good. Straight line speed well below what I would have expected. General presence and 'groove' was just not there. I had expected much better things. C of G is spot on - I did try moving it forward to fly more solid, then rearward to see the effect - not much. Lipos are in good condition as well. Anybody else have any experiences with this a/c that they are willing to share? RH 2500 3S 20 C is the minimum recommended Mine's The same 2500 3S EVO 20C Tornado 40 Amp ESC Seems very slow compared to standard Kyosho 45 EDF landed after 4 mins in no wind and needed a helper to hand launch ( could only hand launch it myself off a slight slope of about 10 feet as it's hard to hold in one hand ) Maybe there to much voltage drop with the long leads to the ESC and can't see 3200 20C 3s being much better Q&EF review looks exaggerated and misses points like the English instruction control throws are wrong use the French or German Values Overall feels slow and pokeless but easy to see and control I expected it to fly at 50% throttle say 20A continous but neaded to be all out so it started to slow after two mins The review hints at the use of a 3700 3S 20C pack but maybe 3700 20C 4s would be better even risking a little overspeed of the fan ? The manual fails to reccmmend an ESC size anyway ! but 60A may be nearer the mark ? BTW I tacked my Fan cover in with thick CA before taping with silver Gaffa tape as I did not want to risk it falling out Also check your servo lead length before glueing aileron servo extensiions in the fuz When joining the Fuz halves I just thick CA'd the center part and then worked round the edges with medium CA and Kicker in hand Looking forward to more comments Thanks Martin I watched the video with the sound off (the sound makes look faster) certainly my circuit performance was similar for the first couple of minutes and about the same for the slower flypasts but I certainly would or could not match the fast vertical stufff
< Message edited by martinh -- 8/1/2007 5:17:41 PM >
