Putting HBKII blades on a CP Pro
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> Esky Helicopters >> Putting HBKII blades on a CP Pro
Page: [1]
Login
Putting HBKII blades on a CP Pro - 6/18/2007 3:46:32 AM
sportsman67
Status: offline
Hi, I was looking at the comparisons of the CP Pro and HBKII adds and noticed other than the belt drive system and the main rotor diameter they are close to the same. The CP Pro's dimensions are 20.7" long, 20.3" main rotor dia., 5.8" tail rotor, it uses a 370 motor with a 9-tooth pinion and 800 mah lipo battery. The HBKII's dimensions are 21" long, 23 5/8" main rotor dia., 5 1/8 " tail rotor, it uses a 370 motor with a 9-tooth pinion and a 1000mah lipo battery. They are so close I was thinking that someone who had both could tell me if the HBKII's main rotor blades fit and work on the CP Pro? I don't think the motor on the CP Pro will have trouble turning the extra length because it does not have to turn a belt like the HBKII and if it did then instead of a stock motor maybe a orion slo-max 300 would be powerful enough. Other than that maybe clearances could be to tight or maybe they won't fit the blade grips so if you own both let me know if this will work, if it does maybe the CP Pro could gain a little stability from using the longer HBKII blades. Thanks Rick
       Post #: 1
RE: Putting HBKII blades on a CP Pro - 6/18/2007 4:03:30 AM
Whirley Bird
Status: offline
Rick,
If your speaking of wooden HBK-V 2,they blades they will work.
I have F/C blades on my HB 2 and each blade is a tad over 1/2" longer then the stock wooden blades.
I also use the larger tail blades from the Falcon on the HBK V-2
Whe weight between the wood and F/C blades I think was 29.6 grams
A penny is showing 22.6 grams so their is just about no weight to speak of to warrant getting some super mega motor.
Vegas./
_____________________________
Vegas/
The only Easy Day Was Yesterday.
(in reply to sportsman67)
       Post #: 2
RE: Putting HBKII blades on a CP Pro - 6/18/2007 2:49:05 PM
honda70kid
Status: offline
hey do u kno how to replace a inner shaft on a blade cp pro???
(in reply to Whirley Bird)
       Post #: 3
RE: Putting HBKII blades on a CP Pro - 6/19/2007 12:24:54 AM
mrasmm
Status: offline
quote:
ORIGINAL: honda70kid
I think you may be in the wrong forum =)
it's all good though, it's your first post! welcome to rcu =)
where you want to post eflite q's is here
http://www.rcuniverse.com/forum/forumid_447/tt.htm
as far as the inner shaft and how to replace it on a cp pro.... umm... I have no idea, the cp pro doesn't have an inner shaft =)
check out www.bladecprepair.com though for the cp, and the cp pro (although the pro is a bit different most of the instructions still apply)
I don't always check every thread I respond to, so feel free to PM me
(in reply to honda70kid)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.578RCU4
