Flyboy Dave
CA, USA Status: offline
...it looks like the lads at Wikopedia don't know what the ribs (rooling hoops) on the 55 gallon drum are for either. "In accordance with practices conventional drum walls are made with two rolling hoops, which are generally outwardly extending annular protrusions formed about the outer circumference of the drum. The rolling hoops are vertically spaced from each other along the length of the drum wall. If the rolling hoops are shaped at an acute angle, the vertical strength of the wall is diminished which adversely effects the adaptability of the drums to vertical stacking." http://www.patentstorm.us/patents/5730315-description.html As a matter of fact....the rolling hoops weaken the sides of the drum, and the drum is more likely to collapse. Also, the sides of the drum don't need to be made more rigid. Their round shape gives it enormous strength....just like an egg....and when the drums are full, they certainly don't need to be made more rigid. Fact is, pallets of drums are stacked one on top of the other. If one wanted make the sides "more rigid" and strenghten them to keep them from collapsing.... ....the ribs would be running vertically on the sides of the drum. Just keeping the record straight. FBD.
< Message edited by Flyboy Dave -- 6/23/2007 11:01:59 PM >
_____________________________
An engineer says.... "That won''t work". A mechanic says..."Oh yeah, watch this". "Old Age, and Treachery will overcome youth and skill". Revver Bro #4.
