RE: OFFICIAL WHEELY KING CRAWLER THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: OFFICIAL WHEELY KING CRAWLER THREAD
Page: <<   < prev  13 14 [15] 16 17 18 19 20 21 22   next >   >>
Login
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/10/2008 5:33:41 PM
learning2crawl
Status: offline
Go up to a 3600 or 3800 it is an extremely noticable improvement. I have had no problem out of the stock motor but I did fry my ESC so I up graded to the rooster crawler....Also another cheap upgrade is to weight the front wheels. However if your running stock wheels and tires I wouldnt rec. dismantling them it would be more trouble than its worth. Some of the guys I know have injected antifreeze into the stock front tires and it actually worked well. However the new thing is bicycle tire slim it didn't leak like the antifreeze did (over time). I have done alot more to my King since the last I have posted I'll try to get some updated ones soon.....
_____________________________
No rock to big....^....^...^
(in reply to tmaxx_man87)
       Post #: 351
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 1:38:31 AM
saturnv7890
Status: offline
Hey guys, I'm thinkin about getting a wheely king, and convert it to a crawler.
based on what i've been reading, I made a list of stuff i'll need to make one. Heres what i've come up with, tell me if i did anything wrong here:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTSY2&P=0
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPCV5&P=ML
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=HPIC8309&P=7
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDDY3&P=M
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXD871&P=M
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK027&P=ML
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSU36&P=M
will that alluminum tube fit over the threaded rod? That's gonna be for this part
also, are there any issues here?
thanks!
       Post #: 352
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 2:05:24 AM
dacaur
Status: offline
the tubing should fit. One thing, you can save a bunch of money by just going with one set of t-maxx driveshafts instead of 2 sets of savage shafts. Take out both savage shaft sets and instead get this http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVPROFIL=++&FVSEARCH=4951x Then use the stock output shafts from the tranny and axle with the stock black u joints instead of the silver ones that came with the shafts, cut 25mm of each outer shaft and 22mm off each inner shaft, and you will be set, plus you save $26.29!!!
(in reply to saturnv7890)
       Post #: 353
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 3:21:57 AM
szechuanpork
Status: offline
I guess the antifreeze/tireslime would explain this: 80 degree wall . Was wondering how he did that.
(in reply to learning2crawl)
       Post #: 354
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 5:14:24 AM
s7jstep1
Status: offline
does anyone know of a reversible way to lock my diffs?
4th of july: celebrate the independence of your country by blowing up a small part of it
(in reply to szechuanpork)
       Post #: 355
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 5:17:41 AM
The Real Dogman
Status: online
Google is you friend!!!!
Just one exampe,, good price too
http://www.rcplanet.com/ProductDetails.asp?ProductCode=SPTSTA30440S&click=3
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Matrix Arena/Wheely King Tuber/Axial Co
(in reply to s7jstep1)
       Post #: 356
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 5:40:13 AM
s7jstep1
Status: offline
yeah i saw something like that already, i was just wondering if i could do it with materials around the house since i dont want to wait for the parts to arrive lol.
(in reply to The Real Dogman)
       Post #: 357
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 5:47:51 AM
tmaxx_man87
Status: offline
maybe you could use some brake line, cut it to the length of the diff, and fill it with jb weld, push the axles in, pull them out, and let dry.. if ya understand what im saying i think it would work...
tmaxx.. wheely king in the mail... crawler parts waiting..
       Post #: 358
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 6:07:39 AM
s7jstep1
Status: offline
quote:
ORIGINAL: tmaxx_man87
yeah i was hoping for something reversible incase i want to run without the diffs locked. ill probably go with what dogman linked
       Post #: 359
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 1:37:46 PM
Neverdone
Status: offline
you can also use the lockers from the ax10 they are a direct bolt in but they are a bit more pricey about 10 each
Full bore and a little more
       Post #: 360
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 4:47:11 PM
tmaxx_man87
Status: offline
the brake line thing is revursable... you pull the axles out of the jb and wait to dry... insert and go..
(in reply to Neverdone)
       Post #: 361
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/11/2008 7:43:32 PM
s7jstep1
Status: offline
ok i see now. i was kinda confused on what you were saying.
       Post #: 362
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/12/2008 4:12:51 AM
hands without shadows
Status: online
I finally started working on the WK again this weekend. This is my 4th servo mount design and the first one I'm truly happy with. This is just a rough copy, the next copy will have a minor modification to it which will allow it to be used on both the front and rear axles. The servo will be clamped down by a plate that goes overtop of it and bolts to the bottom plate so there is no chance of breaking servo ears (I break those alot). There is room on the axle for a split 6 or 8 cell 2/3A pack or a small lipo right on top of the servo if wanted. Now I need to make some link mounts I can live with.
This was my 1st design, made with a template I found on RCC. It works for some people but it would contact my tires during full steering. Never try to make any RC parts out of 3/16" steel when 1/8" aluminum is more than adequate.
This was my second mount that I don't have any pics of besides this CAD view. It broke servo ears twice before I scrapped it.
This was my 3rd design that I don't have any pics of besides this CAD view. I tried mimicking the second design but bringing the servo as close to the axle as possible. It was obviously too weak and scrapped after the first run.
< Message edited by hands without shadows -- 2/12/2008 4:15:05 AM >
_________
O||||||||O
       Post #: 363
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 2/12/2008 4:52:35 AM
dacaur
Status: offline
looks good, cant wait to see what you come up with....
(in reply to hands without shadows)
       Post #: 364
