RE: OFFICIAL WHEELY KING CRAWLER THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
Associated MGT 8.0 - RTR
Seller:  ScottInMichigan
Details:   $450.00   |  10/6/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: OFFICIAL WHEELY KING CRAWLER THREAD
Page: <<   < prev  16 17 18 [19] 20 21 22 23 24 25   next >   >>
Login
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/9/2008 11:52:57 PM
dacaur
Status: offline
quote:
ORIGINAL: Dekz
quote:
ORIGINAL: dacaur
stick on lead tire weights in the front tires will help, but its really not going to crawl well till you stretch the wheelbase.... try a chassis flip, you will like it, and you can use the stock battery box again.
I was under the impression that the steering wouldn't reach if you flip the chassis. Or is that only if you flip AND stretch?
The stock setup will just barely reach when you flip (definatly not when you stretch), but like learning2crawl said, the stock setup is pretty crappy... its OK for doing wheelies, but far from acceptable for rock crawling. I started with the stock servo on the front axle, and recently upgraded to a hitec 645MG HT servo.... the difference going from the stock servo to the hitec, was about the same as the difference going from stock steering to axle mounted with stock servo
As for the wheelbase, longer is better. the longer it is, the easier it will be to tackle obstacles (well, to a point, at some point your break over angle will be what kills you rather than length) a 15" WB makes crawling much easier true, but we arent rock crawling because we are lazy and like to do things the easy way, now are we? We are doing it for the challenge, and staying within rockcrawling rules, even if you never plan to compete makes it that much more satisfying when you make an obstacle... (mine is just about 12" right now)
Also, depending on how you mount your servo, you may or may not rotate your link mounts, I mounted my servo in the center so didnt rotate my mounts.
No the servo never hits the chassis when crawling.
< Message edited by dacaur -- 4/9/2008 11:55:19 PM >
(in reply to Dekz)
       Post #: 451
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/10/2008 2:28:39 AM
hands without shadows
Status: online
An axle mounted servo is way more efficient, compact, and centers weight over the front axle. If you don't want to design something yourself there are plenty of templates available: http://cid-4a947c0fd105ba34.skydrive.live.com/browse.aspx/WK%20Templates
_____________________________
_________
O||||||||O
(in reply to dacaur)
       Post #: 452
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/12/2008 12:15:14 AM
xz1gsw
Status: offline
Here is my wheely king. I had the body aying around for years. I would like to exend the wheel base but then the body would not fit.[image][/image]
Click to see fullsize image.
Click for fullsize
(in reply to hands without shadows)
       Post #: 453
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/17/2008 1:45:13 AM
bronx boy
Status: offline
has anybody busted the differential my god son beats on this truck for almost a year now i have a mild 23 turn motor in last week or so i noticed the rear end making a clicking noise sounds like the differntial is letting go is this common in these trucks i had to replace the spur gear once so i checked that first its deffinitly in the rear end
(in reply to xz1gsw)
       Post #: 454
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/17/2008 7:08:14 PM
lowdown
Status: offline
OK, I've been lurking here for a couple of weeks now and drooling!
I decided to bite the bullet and bought me a Wheely King and started ordering parts.
This thing is a blast!
I've just about got it where I want it, there are no competitions around here this is just an adult toy.
STRC suspension and steering parts (11 1/2" wheel base)
Traxxas T-Maxx drive shafts
Flipped chassis (sort of... adding rear steering made this really easy, I just added a servo mount to the rear axle and flipped the wires to the motor)
4 wheel steering with Hi-torque metal geared servo in front
Novak Rooster Crawler esc with Novak 55 turn motor
STRC motor heat sink-blue
48p 96t spur gear and 14t pinion gear
RcGuy diff lockers
Axial Bead locks with 2.2 Moab tires - lead wheel weights in all 4 wheels
Modified Traxxas TQ3 3 channel radio (for rear steering)
Punk Rock Steering computer coming for better control of the rear steering
More plans in the future but this is a good start [)]
lowdown
< Message edited by lowdown -- 4/17/2008 7:33:16 PM >
(in reply to bronx boy)
       Post #: 455
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/19/2008 5:49:42 AM
s7jstep1
Status: offline
thats a nice rig. are you going to get a different body for it?
4th of july: celebrate the independence of your country by blowing up a small part of it
(in reply to lowdown)
       Post #: 456
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/19/2008 6:10:53 AM
lowdown
Status: offline
I am, I bought the Wheely King used (it was like new) with the suspension set up already on it. I added the 4 wheel steering, flipped the chassis and replaced all the electronics. It came with 3 bodies - the one on it, a new unused (blue) wk body and a Hummer, I am not real fond of any of them.
I haven't decided which body I want yet, I'm going back and forth between the Jeep Rubicon body and the 72 Chevy C-10.
lowdown
(in reply to s7jstep1)
       Post #: 457
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/23/2008 12:42:07 AM
jasoka
Status: offline
Mine
       Post #: 458
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 4/23/2008 6:04:14 PM
lowdown
Status: offline
I got my Punk Rock Steering computer from Clod Mod Racing and installed it...
VERY KOOL!
No with the flip of a switch (on the fly) on my modified TQ3 radio I can go from 2ws to 4ws or crab walk.
It works very nice.
I also tore into it and removed the blue lower arms and replaced them with the traxxas arms, flipped the shock mounts on the axles and now I am right at 12" wb.
lowdown
       Post #: 459
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 5/2/2008 10:02:08 PM
Ace76
Status: offline
What do you all think about the new crawler conversion from HPI. Is it better to just buy the parts and do it your self? Here's the link.
http://www.hpiracing.com/products/en/87633/
       Post #: 460
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 5/2/2008 11:43:19 PM
Status: online
quote:
ORIGINAL: lowdown
VERY KOOL!
It works very nice.
lowdown
You know you can have independant front and rear steer with that radio right? Thats more control and you dont need the computer.
_________
O||||||||O
       Post #: 461
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 5/3/2008 12:09:22 AM
lowdown
Status: offline
Yes, I do know that, that's how I had it set up originally but I didn't like the rear steering non proportional. I don't compete and I used to have a Clod Buster so this feels more natural to me.
I personally really like the steering computer. The idea of independent steering is nice but I didn't care for it just being a switch for full right/center/full left.
       Post #: 462
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 5/4/2008 3:00:18 AM
dkchance74
Status: offline
hey guys im new to crawlin and im lookin for a electric crawler to build tht wont break the bank. can u help??? ive got a x factor that i stretched and modded a little. just to much power in the nitro. thanks
       Post #: 463
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 5/4/2008 6:00:46 PM
dkchance74
Status: offline
well guys you talk so much about the WK i decided to get one. i bought one on ebay that is not working right now. it says it has a tazer 15t???? but he said he cant get it to work or program it. will it work with the stock motor and everything else??? and what is the best way to extend it????
(in reply to admiket)
       Post #: 464
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 5/4/2008 6:11:30 PM
