hands without shadows
ON, CANADA Status: offline
You need 3 caps. Here's a cheap set. One cap goes from positive to negative, one goes from positive to ground, and one goes from negative to ground. The caps don't have polarity so you don't have to worry about that. Your stock ESC should be fine but it will probably get hot unless you gear down from stock. I locked out my steering today. Its really simple, really cheap, and looks really clean.
_____________________________
_________ O||||||||O
