RE: OFFICIAL WHEELY KING CRAWLER THREAD
Tower Hobbies
Logged in as Guest
Users viewing this topic: RomanSH
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: OFFICIAL WHEELY KING CRAWLER THREAD
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/21/2007 1:41:16 AM
guver
Status: offline
Well, my WK with 2 lockers turned out to be a dud. The locker work perfect, but given it has a common gearbox and 2 lockers it took a servo that is over twice the stock strrength and it still steers kinda hokey. I guess that's to be expected with only one motor.
I used a 65 t motor and will still have to gear down some more because it isn't very strong on 6 cells. Articulatuion is pretty good with stock stuff. Flipping the chassis proved very time consuming because of stock servo mount. Best to use on on axle in my opinion.
_____________________________
This is an apostrophe ''
(in reply to p3313r)
       Post #: 76
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/21/2007 6:49:43 AM
guver
Status: offline
On lengthening WB: since I'll make my links like on the HPI site shall I make the same lengths as they say F140mm R152?mm
Or would it be better to use equal lengths, my battery is in front and I'd like to stick with a legal 2.2 wb. Maybe I can use maxx links on front and only have to make one set?
(in reply to guver)
       Post #: 77
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/21/2007 7:08:23 PM
guver
Status: offline
Ahaha, I finally ordered parts, hohohoo.
Low gears, ends to make links, narrow wheels without much offset, pinion shims,a new servo box, doh. Maybe I can crawls with the Ohio boys now.
Still wondering about those link lengths, lol.
(in reply to guver)
       Post #: 78
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/21/2007 7:44:03 PM
nickrummy
Status: offline
Guver, Sorry about missing all those posts by you! Ok time to try and answer questions.
- The only shims that I know for the diffs are in this kit
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXTB43&P=M
- rear steering on 2 channels is possible but you have to buy a Y harness. One end plugs into your receiver then the two other ends plug into your servos. A couple problems here. Instead of only one servo pulling power you now have two. Some BECs on speed controls won't like that much and you might have to run a receiver battery pack (adding weight). The other problem is most 2.2 classes don't allow rear steer. We don't care at our get togethers though. 4 wheel steering will be better for turning than just front steering. Simple. It might result in having to buy other electronics though and you might be better off just getting a different radio and running independent rear steer (TQ3 radios are about 20 bucks used and you can mod the switch yourself) You're right, locking the front and rear starts to really hinder steering when you run the stock style linkages. Your best bet is to mount the servo on the axle. There is way to much slop in the linkages when the servo is mounted on the chassis.
- Gearing, I'm running a 13t pinion and a 66t traxxas spur. The stock WK gearing is pretty tall and will stall motors out pretty easily. I run a 65t axiom also but I'm running it at 8.4v.
- If you are asking about the small stamped steel axle mounts I am using they are tamiya parts and are out of stock right now. If you are talking about the plate aluminum on the axle. I made those.
- There a lot of ways to setup the links. The easiest thing to do in my opinion is go out and buy some 6-32 all thread from lowe's or home depot. Cut that into the lengths you think you need and put your rod ends on them. Hook it up to your truck and see how they work out. If it doesn't work then take the links off and shorten them up. If you need longer links then save the shorter piece for future mock ups and cut a new one.
Here is a picture of the all thread with rod ends on my truck when I was mocking the links up.
< Message edited by nickrummy -- 8/21/2007 7:45:56 PM >
(in reply to guver)
       Post #: 79
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/22/2007 1:09:30 AM
s7jstep1
Status: offline
my shocks finally came in
4th of july: celebrate the independence of your country by blowing up a small part of it
(in reply to nickrummy)
       Post #: 80
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/22/2007 6:00:03 PM
guver
Status: offline
Thanks nick. I just got thru a test run, not too bad with stock steering stuff. The lockers sure make it. Some of my tire choices are shorter than the stock ones and I think the tall stock ones might be best when I go to narrow wheels.
choices are older stampede tires, new stampede talon tires, wheelyking tires, I'm trying not to buy any,lol.
what shocks did you get 7?
(in reply to s7jstep1)
       Post #: 81
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/22/2007 6:45:36 PM
nickrummy
Status: offline
Even though the stock WK tires have a big overall diameter they get NO traction what so ever... They're way to hard of a compound and do don't well at all on rocks. Decent in mud
I'd definitely run those talon tires if you can. I know they are smaller but they should have more traction. Don't glue them on right away. Just mount them unglued and go drive it. Be careful because obviously your rims are going to spin in your tires a bit but you should be able to see how the tires compare. Then when you glue them they will be that much better. I run masher 2000s on my truck and crawls way better than when it did with the larger WK tires.
(in reply to guver)
       Post #: 82
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/22/2007 7:08:47 PM
guver
Status: offline
Ok, great info. I'll use the set with the least off-set and try them they are glued from factory. I think it'll be 2 sets of rears from the stampede. If they work good maybe I can mount them on my narrow wheels too.
ps I won't be seeing you this weekend, gotta work have fun.
       Post #: 83
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/22/2007 7:53:47 PM
nickrummy
Status: offline
No biggie, I don't think we are going to have a meet anyhow because of the weather. Most of the guys from out of town aren't coming.
If it dries up I'll be out in medina next week checking out the new track layout if you want to stop by!
(in reply to guver)
       Post #: 84
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/24/2007 6:36:59 PM
p3313r
Status: offline
i just ordered my wheely king and all the things to make it crawl
       Post #: 85
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/24/2007 6:52:07 PM
Lumpmister
Status: offline
quote:
ORIGINAL: p3313r
Sweet... that is the first step!
To Many to List or Remeber.....
Latest Additions: 8T, CRT.5, Scale Blazer 1.9, Aeromax, Mini Slider,
       Post #: 86
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/27/2007 1:25:09 AM
guver
Status: offline
quote:
ORIGINAL: guver
Here's pics of the Talon Pede tires with the narrowest offset (rear stampede) the fronts have a bit more offset and may do a bit better. All in all the stock WK tires did better on my debris ridden trails. Lots of sand, logs, woods. I overlooked the fact that the wheels are 2.8 " too. I may have to order tires after all.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to guver)
       Post #: 87
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/27/2007 1:30:52 AM
MAXX4X4
Status: offline
my truck is mostly a trail truck as you can see here
http://s96.photobucket.com/albums/l165/MAXX4X4/?action=view¤t=Picture283.flv
it can be a "crawler" too lol
enjoy
(in reply to guver)
       Post #: 88
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/27/2007 1:37:00 AM
guver
Status: offline
Nice, I have still yet to stretch mine and use a lipo for weight reduction.
(in reply to MAXX4X4)
       Post #: 89
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 8/27/2007 4:25:27 AM
nickrummy
Status: offline
Looks good guver! I figured you were wanting to crawl that is why I thought the talons might be better than the stock WK tires. they don't get traction on rocks at all. Trucks looking good!
(in reply to guver)
