RE: OFFICIAL WHEELY KING CRAWLER THREAD
Tower Hobbies
Logged in as Guest
  Printable Version
FS Racing Monster Truck 4WD 1/5 Scale Blue - RTR
Seller:  pmwtrading
Details:   $755.00   |  8/29/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: OFFICIAL WHEELY KING CRAWLER THREAD
Page: <<   < prev  4 5 [6] 7 8 9 10 11 12 13   next >   >>
Login
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 9/24/2007 4:08:03 PM
nickrummy
Status: offline
I can see them cleaning out well in mud/dirt since they have a very open tread pattern. We ran in some mud and dirt when I have swamp dawgs on my truck and I couldn't go places that people with the same truck take mashers through. I found that as soon as the swamp dawgs got wet you might as well have plastic tires.
(in reply to ChrisGeorge)
       Post #: 126
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 9/24/2007 4:33:54 PM
ChrisGeorge
Status: offline
That may be the case but these tires are different. Your definitly right about the open tread pattern though these babies
clean anything out quick. Also I understand you problem with the swamp dogs but I dont think they were geared as
much towards rock crawling like the red rocks.
(in reply to nickrummy)
       Post #: 127
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 9/24/2007 4:50:07 PM
nickrummy
Status: offline
I'm sure I'm wrong in doing so but I "assumed" that any imex tire would be mediocre at best when it comes to crawling. Imex told me they make all their tires out of the same rubber compound which is very hard compared to others. When that rubber gets wet watch out! That's the main reason I am not for Imex tires when it comes to competing. Do they look good? heck yeh! Will they work? Yup they roll Will they out perform a masher or losi claw climbing rocks? Well someone would have to show me to prove it.
       Post #: 128
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 9/24/2007 5:05:59 PM
ChrisGeorge
Status: offline
Alright I made my case for the tires. Ia m not going to argue them anymore.
I like them.
You may not.
Are they better than Mashers or Moabs or Rock claws? I cant say from personal experience but no the are most certainly not
any better I would guess. In certain circumstances, mine, they present advantages because of their size and tread.
Again I agree with your assesment of wet traction which is terrible.
I hope this clears things up.
       Post #: 129
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 9/24/2007 6:35:04 PM
nickrummy
Status: offline
Understandable. I wasn't trying to argue just to argue. You stated you didn't agree with my thoughts on the imex tires and I wasn't seeing your point so I was trying to explain my reasoning.
They work for you and not for me. Sounds like good reasoning!
What are you still planning on changing on your truck? I seen you said you still aren't satisfied.
       Post #: 130
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 9/24/2007 7:06:01 PM
RCminded
Status: offline
Well My biggest problem deals with excess weight. As I said before I own an AX-10 and it weighs a mere 3.5ish lbs.
My wk tips the scales at nearly 8lbs. I am sure you can understand my concern with this.
Mainly the truck must work roughly twice as had as the axial crawler, and beleive me it shows.
Secondly the way I mounted the links was inapropriate for full blown competition but at the time
rotating the brakets had not occured to me. I would like to mount those to the back of the axel
when I rebuild. I aslo want to make side plates for it and relocate the electronics possible waterproof box.
Definetly a new body, Bug in orange and purple? Aluminum spindles and their brakets would be good but if not
at least I need to cut the existing ones for better steering. lipo battery and brushless would reduce my weight problems by nearly a pound so that has a big priority. I also plan to eliminate the winch because I dont really use it often and it is weight that is
to high up. Thats all I can think of now.
So just a couple of things!! HA!!
       Post #: 131
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 4:11:12 AM
RCminded
Status: offline
Oh sorry, I forgot to say that this is my new screen name(previously chrisgeorge).
Check out this prototype steering setup. I adjusted the links so that they are up and out of the way but still get full throw. This is a test setup outfited to a freind of a freinds truck. I are going to see what his feedback is. I still have to trim the one link to length but I am waiting for his servo. It should be done tommorrow so i will post up how it worked ASAP.
Click to see fullsize image.
Click for fullsize
       Post #: 132
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 4:37:09 AM
The Real Dogman
Status: online
Is it just me or does it seem kinda silly to make such nice high clearance steering linkage, yet leave the oem link mounts hanging so low??
_____________________________
My Wife Knows How Much It Really Costs And Still Loves(lets)Me!
Nemesis/Genesis/Matrix Arena/Wheely King Tuber/Axial AX
(in reply to RCminded)
       Post #: 133
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 4:08:10 PM
hands without shadows
Status: offline
Dog is right, you could at least rotate the link mounts 90 degrees.
_________
O||||||||O
(in reply to The Real Dogman)
       Post #: 134
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 4:10:21 PM
nickrummy
Status: offline
quote:
ORIGINAL: hands without shadows
If he does that he'll have a lot of suspension reconfiguring to do. Not to mention trimming the link mounts in the front to clear his new steering links.
I would move the bottom links to the same mounting hole as the shocks then shave the bottom of the link mounts. I know the links would be mounted a bit high on the axle but you would have a LOT of work involved to do it the proper way.
< Message edited by nickrummy -- 10/3/2007 4:13:11 PM >
(in reply to hands without shadows)
       Post #: 135
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 6:34:07 PM
Neil E
Status: offline
I rotate the link mounts 90 degrees and did not shave them.
Click for fullsize
Go Crawling in TEXAS
http://www.txrcrca.com
       Post #: 136
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 6:51:23 PM
nickrummy
Status: offline
I always try to clean up the front of the axle as much as possible that way there is nothing to get hung up on.
(in reply to Neil E)
       Post #: 137
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 7:38:53 PM
Status: offline
quote:
ORIGINAL: nickrummy
Besides the axle itself
_________
O||||||||O
       Post #: 138
RE: OFFICIAL WHEELY KING CRAWLER THREAD - 10/3/2007 7:43:30 PM
nickrummy
Status: offline
Exactly! The more clear room you have from the front of the axle to the front of the tires the better approach you'll have.
See, nice and clean
< Message edited by nickrummy -- 10/3/2007 7:44:10 PM >
