Skybolt hangar and clubhouse    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Kit Building >> Skybolt hangar and clubhouse
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
Skybolt hangar and clubhouse - 6/19/2007 5:36 AM
biplanemurphy
Score: 100
Last Login: 2/2/2012
Status: offline
Share your Skybolt photos and discuss flight performance . Don't forget performance enhancing modifications.
Mine weighs about 11 lbs. Has smoke system. O.S. 120FS surpassIII W/pump. 5" wheels (no wheel liederhosen)
standard Hitec servos. 14x10 master airscrew "scimitar" prop. Fully sheeted wings. du-bro remote fuelng valves for glow and smoke.
Push-pull switches. Air-alert warnng beacon. 14 oz. fuel tank. 8 oz. smoke oil tank.
2- 1650mah ni-mh 6 volt batteries for reciever and smoke system.
Covered in Monocote.
Cowl and struts primered, painted with lustrecote, painted with finishng epoxy for fuel proofing.
Usng 20% nitro fuel.
Using "Super-Dri" aviation smoke oil.
Murphy..................
P.S. here's mine.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Flyin'' in the desert.
Tumbleweed Flats Flyers.
Hide Signatures
       Post #: 1
RE: Skybolt hangar and clubhouse - 6/19/2007 6:08 AM
ChrisMH
Score: 100
Last Login: 3/7/2013
Status: offline
I'll add mine
11 lbs, Saito 1.20, Covered in Koverall and dope.
Edit: 10lbs 6oz after installing a hatch and moving my rx battery forward.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by ChrisMH -- 6/22/2007 11:28 AM >
Chris Hogan
WACO Brotherhood #15 - http://www.houseofmoy.com/waco
Hide Signatures
(in reply to biplanemurphy)
       Post #: 2
RE: Skybolt hangar and clubhouse - 6/19/2007 6:16 AM
biplanemurphy
Score: 100
Status: offline
Sweet plane Chris........I was hoping to see yours here.
Hopefully we can get Minnflyer (supreme commander of all things Skybolt ) to post some pics of his (past and present).
Keep em coming guys. Tell us how she flies too.
Mine flies like it's on rails. "crosswind? What crosswind?"
Murphy....
< Message edited by biplanemurphy -- 6/19/2007 6:22 AM >
Hide Signatures
(in reply to ChrisMH)
       Post #: 3
RE: Skybolt hangar and clubhouse - 6/19/2007 6:32 AM
biplanemurphy
Score: 100
Status: offline
So .....here's a Skybolt story......About the 5th flight, I was starting to feel real comfortable and flew a little too long.....
On approach I ran out of fuel and barely made it over the trees at end of runway. Stalled so pointed her down and recovered. Made it to 4 feet above the deck and she stalled again. dropped 4 feet straight down like an elevator. Landed on all three wheels!!
But splayed that soft aluminum gear. No real damage. Bent it back and flew her again after I stopped shaking.
Spent over a year slowly building this one, so you can imagine how happy I was to keep her in one piece!!
Murphy........
Hide Signatures
       Post #: 4
RE: Skybolt hangar and clubhouse - 6/19/2007 7:15 AM
biplanemurphy
Score: 100
Status: offline
Hey guys.....I have a smoke system question?
I have a sullivan Skywriter and used the black hose for the hook up to the nipple on my muffler. It melts a hole through it every
3 flights. Any hose/line that is really heat resistant. my four-stroke muffler gets real hot it appears. Makes great smoke, but melts the smoke oil line.
Murphy........
Hide Signatures
       Post #: 5
RE: Skybolt hangar and clubhouse - 6/19/2007 7:24 AM
MinnFlyer
Score: 390
Last Login: 4/27/2012
Status: offline
What smoke oil are you using?
Mike B. AMA# 42400 www.gettingairborne.com
Ultra Sport Brotherhood #2 - Waco Brother #188 - Cub Brother #2
"Those are my principles. If you don’t like them, I have others." - Groucho Marx
Hide Signatures
       Post #: 6
RE: Skybolt hangar and clubhouse - 6/19/2007 7:40 AM
biplanemurphy
Score: 100
Status: offline
Minnflyer.......Super-dri aviation smoke oil. My O.S. 120 w/pump had a screw where the exaust pressure nipple would be.
So I installed a pressure nipple and feed the oil in at that point.
Murphy......
P.S. I'm considering soldering some copper tubing to nipple and extending the mounting point for black tubing about 3".
Maybe coil the tubing around exaust header then a long extension 4-5" out to plug black tubing into.
Do you think a preheater coil would make it smoke even better? It already smokes pretty darn good now.
Thanks for any help/ideas .
Hide Signatures
(in reply to MinnFlyer)
       Post #: 7
RE: Skybolt hangar and clubhouse - 6/19/2007 3:58 PM
hrrcflyer
Score: 121
Last Login: 5/22/2013
Status: offline
Here are a few pictures of the one I had. It suffered an untimely death.
Fly safe and have fun!!
David
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fly Safe and Have Fun ! ! !
Ultra Sport Brotherhood #22
Hide Signatures
       Post #: 8
RE: Skybolt hangar and clubhouse - 6/19/2007 4:31 PM
Gringo Flyer
Score: 110
Last Login: 11/28/2011
Status: offline
quote:
ORIGINAL: biplanemurphy
That seems pretty heavy. I knew skybolts tended to build heavy but I didnt realize they were that heavy.
"Courage is being scared to death...and saddling up anyway."---John Wayne
Hide Signatures
       Post #: 9
RE: Skybolt hangar and clubhouse - 6/19/2007 8:03 PM
Deadeye
Score: 119
Last Login: 5/23/2013
Status: offline
Here's mine. A tad over 9 pounds, with lightening methods employed to reduce tail weight. Magnum 120, 15X8 MAS Classic. Fast freaking plane for a bipe! Pilot is 'Stewey' of Family Guy fame. Over a hundred flights on it now.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Randy Rossmiller, member, Golden Triangle Flyers
Theres no such thing as too much power. Member, Club Saito
Ultra Sport Brotherhood #52
Hide Signatures
(in reply to Gringo Flyer)
       Post #: 10
RE: Skybolt hangar and clubhouse - 6/19/2007 10:02 PM
biplanemurphy
Score: 100
Status: offline
Beautiful planes guys..........I thinnk mine is heavy due to the massive amounts of glue and epoxy I used. Added extra wood.
smoke system. and OS 120 four stroke weighs 2 lbs all by itself.
Murphy........
Hide Signatures
(in reply to Deadeye)
       Post #: 11
RE: Skybolt hangar and clubhouse - 6/20/2007 3:37 AM
WYDAH
Score: 100
Status: offline
Hi,
Here's a few of my Skybolt. Weighing in at 10.5lbs. Has a GMS .76 (yes, 2 stroke) swings 12x6 APC. No smoke. Completed May 2003. Great flying plane.
Click for fullsize
Click for fullsize
Click for fullsize
-Wydah
Visit My RC Aircraft Site: http://WYDAH.sky.prohosting.com
Hide Signatures
       Post #: 12
RE: Skybolt hangar and clubhouse - 6/20/2007 7:04 AM
micagreenmachin
Score: 100
Last Login: 11/29/2008
Status: offline
Ok, here's what it USED to look like... Don't worry, it's still in one piece. I flew it SO MUCH I wore out the covering and am refinishing it right now. New pics soon...
Click for fullsize
Click for fullsize
Click for fullsize
Everytime you take-off, at some point you're gonna have to land...
Hide Signatures
       Post #: 13
RE: Skybolt hangar and clubhouse - 6/20/2007 7:06 AM
tukkus
Score: 100
Last Login: 1/8/2012
Status: offline
I think I have the heaviest GP Skybolt at 12lbs dry, it had an OS 91 on it but it wasn't enough power so I'm going to put a YS 120 on it and see how it goes. If the 120 isn't enough I also have a YS 140L that I can try too.
I'll get some pictures of it this weekend.
I also have a Sig Skybolt that needs some repair but that will most likely be a winter project.
Hide Signatures
(in reply to WYDAH)
       Post #: 14
RE: Skybolt hangar and clubhouse - 6/20/2007 7:27 AM
biplanemurphy
Score: 100
Status: offline
micagreenmachin.............super nice covering job!! You must have had hundreds of flights to wear it out. How's that saito work for it? What size? How does she fly etc...
tukkus..12 lbs. with a 91 even. do you have smoke onboard? You must have used even more epoxy than I did !!
Murphy..........
Hide Signatures
(in reply to tukkus)
       Post #: 15
RE: Skybolt hangar and clubhouse - 6/20/2007 2:44 PM
telejojo
Score: 130
Status: offline
WYDAH,did you put the black on the wings first or yellow? I'm thinking of recovering my DP Ultimate.All of the Skybolts in this thread look great.
Hide Signatures
(in reply to WYDAH)
       Post #: 16
RE: Skybolt hangar and clubhouse - 6/20/2007 6:35 PM
micagreenmachin
Score: 100
Status: offline
Murphy..........
She flys awesome! She weighs 8.5-9 lbs and performs well on a Saito 100. She'll weigh a little more after I'm done re-covering her since she's getting a smoke system! Some fuel/oil worked its way under the covering on the belly and on the bottom of the lower wing and I wound up replacing a lot of soaked wood. She'll be better than new when I'm done with her.
Thanks!
-t
Hide Signatures
       Post #: 17
RE: Skybolt hangar and clubhouse - 6/21/2007 6:39 AM
WYDAH
Score: 100
Status: offline
Hi Telejojo,
I first covered it with the yellow (Ultracote), and then put on the black sunburst pattern using low heat to keep the bubbles to a minimum. The checkerboard on the bottom of the wings and the rudder are pre-printed black/yellow Ultracote that Horizon Hobbies sells. I think you can even buy it with different size squares now, 1/2", 1" and even 2" squares.
Click for fullsize
Click for fullsize
-Wydah
Hide Signatures
(in reply to micagreenmachin)
       Post #: 18
RE: Skybolt hangar and clubhouse - 6/21/2007 7:15 AM
biplanemurphy
Score: 100
Status: offline
WYDAH..........I use that same stand to build/repair etc. in !!!!
Thanks for all the good photos and tips etc.. guys.
Murphy........
Hide Signatures
(in reply to WYDAH)
       Post #: 19
RE: Skybolt hangar and clubhouse - 6/21/2007 7:34 AM
Mods-R-Me
Score: 103
Last Login: 2/4/2012
Status: offline
It makes an improvement on my Skybolt. Here's how I did it.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Mods-R-Me -- 6/21/2007 8:03 AM >
Kelvin "Mods"
Hide Signatures
       Post #: 20
RE: Skybolt hangar and clubhouse - 6/21/2007 7:40 AM
Mods-R-Me
Score: 103
Status: offline
Here's a few pics of mine. I made a double cowl mod to fit the pitts muffler and a smoke system. Also fitted external fill valves for the smoke and glow tank.
Mods
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by Mods-R-Me -- 6/21/2007 7:47 AM >
Kelvin "Mods"
Hide Signatures
(in reply to Mods-R-Me)
       Post #: 21
RE: Skybolt hangar and clubhouse - 6/21/2007 7:48 AM
biplanemurphy
Score: 100
Status: offline
Hi Mods........Your thread and my building mentor as well, both inspired me to maybe give the copper tubing a try.
I'm sick of melted smoke oil tubing.
Thanks.........Murphy.......
P.S. Love the "JOWL COWL"!!!!!!
Hide Signatures
       Post #: 22
RE: Skybolt hangar and clubhouse - 6/21/2007 4:04 PM
MinnFlyer
Score: 390
Status: offline
Hey Murph, try using regular glow fuel tubing. I've been soaking some in Super-Dri for over two years and it's still good.
Hide Signatures
       Post #: 23
RE: Skybolt hangar and clubhouse - 6/21/2007 7:57 PM
biplanemurphy
Score: 100
Status: offline
Minnflyer........I had that thought too. But unexplicably the heat from muffler melted it too. This makes no sense because the pressure nipple I installed is in the pretapped hole the non-pumped O.S.120 4-s uses.
I'm still running the engine a bit rich. Run 1 3/4 gallons of 20% through it so far.
Thanks for help...........Murphy........
Hide Signatures
       Post #: 24
RE: Skybolt hangar and clubhouse - 6/21/2007 8:59 PM
spanishflyer
Score: 105
Last Login: 1/13/2012
Status: offline
Hello Everybody:
Here is mine:
It has an Ys-110 and it´s plenty of power, but the plane in fact is heavy, I didn´t any lightening holes in tail and I had to add 150 gr lead in the nose... That was after the first flight, CG was wrong calculated and the plane was almost crazy but with some luck I landed without problem.
I have few flights with it, but except of weight it flyes very nice, I need some time with it to try some aerobatics...
I made some changes:
the original wing struts didin´t like to me so I decided to glue two plywood pieces to original ribs an fix the strut with two screws.
I use a pull-pull system in rudder, and also for the Katoh part that moves the split elevator.
In photos you can see that changes. I hope you like them.
Thanks.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.109RCU1
