Cool new blades for DF
Tower Hobbies
Logged in as Guest
  Printable Version
E-Flite Blade CP Pro - RTF
Seller:  hhager2
Details:   $500.00   |  11/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Helicopters >> Draganfly Innovations Products >> Cool new blades for DF
Page: [1]
Login
Cool new blades for DF - 6/19/2007 5:17:13 AM
BB_DF
Status: offline
New Blades!
Mike at Spectrolutions asked me to check out these new blades they're making for the DF. They are milky/clear nylon, and Mike said they're stiffer than the black ones. I could detect only a slight difference in the stiffness, but they definitely were a bit straighter, did not curl up at the ends that the black ones, and most importantly they are very consistent in their shapes one to the next. I've noticed the black ones really vary, sometimes even the two ends of the same blade, but these clear ones were all perfectly straight. They cone up like the black ones do, and seem to be very stable. I don't know if it was just my imagination, but they seem to fly better. One thing for sure is they look really good in the air. I flew late in the evening and the blades completely disappeared against the sky.
This would be a really interesting product: they have tail rotor blades that glow brightly in the dark, and are charged by a UV LED mounted on the tail boom. Wouldn't it be nice to have clear rotors like these that would glow different colors for orientation at night!
You'll like these blades.
Cheers,
Bruce
Click to see fullsize image.
Click for fullsize
       Post #: 1
RE: Cool new blades for DF - 6/19/2007 6:27:05 AM
Old Man Mike
Status: offline
I want a set NOW!
One thing that I have noticed is that the black blades sometimes hit the frame during some rapid movements. Have you noticed this with the older blades and if so, can you comment about the performance of the newer blades in this regard?
Mike
(in reply to BB_DF)
       Post #: 2
RE: Cool new blades for DF - 6/19/2007 4:25:49 PM
BB_DF
Status: offline
Hi Mike,
I also noticed with the black blades when it was windy, you'd hear them clicking on the frames. I've only flown with these once so far and it was very calm, so I'll have to get more time on them. However, if they are a bit stiffer like Mike Dammar said, there should be less contact.
- Bruce
(in reply to Old Man Mike)
       Post #: 3
RE: Cool new blades for DF - 6/21/2007 12:12:09 PM
Dirk Schooner
Status: offline
Just been to spectrosullutions site, no sign of these blades yet, any idea when they will be available, not keen on the bendly floppy bat wings i have currently attached!
(in reply to BB_DF)
       Post #: 4
RE: Cool new blades for DF - 6/28/2007 9:52:01 PM
BB_DF
Status: offline
Hi Dirk,
The new blades are now available on the Spectrolutions web site, under DraganFlyer accessories. Mike Dammar says they are just a bit stiffer, and perhaps a bit more efficient. They're now got the blades in various colors, and a more complete line of other DF repair components as well.
Cheers,
Bruce
(in reply to Dirk Schooner)
       Post #: 5
RE: Cool new blades for DF - 6/28/2007 10:45:57 PM
Old Man Mike
Status: offline
I've got a set on order. Have you done any additional flying with the new blades and if so, notice any frame hits?
Mike
(in reply to BB_DF)
       Post #: 6
RE: Cool new blades for DF - 6/29/2007 12:47:42 AM
BB_DF
Status: offline
I've flown the new blades quite a bit and haven't heard any clicking on the frames. However, the other blades only did it once in a while, usually when I was descending quickly and it was windy. I have no doubt the new blades are better, though. You can tell a slight difference in the stiffness, but the main difference I've seen is that they don't curl up on the ends as much.
- Bruce
       Post #: 7
RE: Cool new blades for DF - 11/8/2007 4:11:23 AM
jonyprofit
Status: offline
I recently switched to the new blades and added the frame bracing kit, now i barely get 1 -2 minutes in the air compared to almost 10 mins. before on my V Ti. Are the original equipment pilots using 1320 Li batteries or have you moved to 2000mAh? Thanks and I'm glad i found this site.
(in reply to BB_DF)
       Post #: 8
RE: Cool new blades for DF - 11/8/2007 4:48:08 AM
Sky High
Status: offline
quote:
ORIGINAL: jonyprofit
I recently switched to the new blades and added the frame bracing kit, now i barely get 1 -2 minutes in the air compared to almost 10 mins. before on my V Ti. ...
I don't see how either of those changes would affect flight time. Maybe your battery's life is almost spent. The larger battery will last longer but mostly if you're just hovering. If you fly agressively or descend too fast and then give it throttle to recover, that added weight makes it work harder.
_____________________________
Up there, you don't have time to think, if you think, you're dead!
Never mess with a pilot having more rotors than you!
(in reply to jonyprofit)
       Post #: 9
RE: Cool new blades for DF - 11/18/2007 12:52:47 AM
FL_PI
Status: offline
I know that I am still a newbie too, Sky, but what if he had put the A blades where the B blades go and vice versa?
Ed
(in reply to Sky High)
       Post #: 10
RE: Cool new blades for DF - 11/18/2007 1:00:04 AM
Sky High
Status: offline
quote:
ORIGINAL: FL_PI
If that was the case, he wouldn't even get off the ground because there wouldn't be any lift.
(in reply to FL_PI)
       Post #: 11
RE: Cool new blades for DF - 11/18/2007 1:02:15 AM
FL_PI
Status: offline
I put the new blades on my V TI and never lost ANY flying time. I am still using the 1320 mah batteries that came with my unit. I bought an extra, so counting the video receiver battery, I have three that I rotate in flight use. All get something over or around ten minutes. I set the timer on the transmitter (ten minutes) and after the time alarm sounds I still have a few minutes to mess around before it gets to where I have to shut down. But I am NOT flying HIGH or HARD either....
As for the blade change, for *me* it was a MAJOR change in how the DF flies. It was like a totally different machine.
Ed
       Post #: 12
RE: Cool new blades for DF - 11/18/2007 1:06:28 AM
FL_PI
Status: offline
quote:
ORIGINAL: Sky High
quote:
ORIGINAL: FL_PI
Yes, Sky, exactly my point. Maybe he was beating the air so hard that he got no flight time. I understand the lift from the blades and reversing them shouldn't allow lift, but (as a newbie) I can not think of ANY reason that just changing blades and adding frame stiffeners would make a 90% drop in flight time(s).
And I *THOUGHT* (since I have one) the V TI came with all the frame stiffeners installed....? Mine did.....
Ed
       Post #: 13
RE: Cool new blades for DF - 11/18/2007 1:16:59 AM
Sky High
Status: offline
He specifically said in the air.
(in reply to FL_PI)
       Post #: 14
RE: Cool new blades for DF - 11/18/2007 4:44:03 AM
FL_PI
Status: offline
quote:
ORIGINAL: Sky High
OOps! How silly of me!
Well then..... lemme go to get back to my *own* problem!
Still gotta figure out why mine is acting up....!
Have a good weekend!
Ed
