old Quadra?
Tower Hobbies
Logged in as Guest
  Printable Version
CRRC-Pro GF26I 2 stroke gas engine
Seller:  jewillis2
Details:   $239.00   |  11/2/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> old Quadra?
Page: [1]
Login
old Quadra? - 2/22/2002 9:02:29 PM
Dixie
Status: offline
Recently purchased an old piper cub 25% it has what I think is a Quadra engine it has an 80 stamped on it and made in canada.I need a ring and a bearing for the rod also all specs and what the fuel mix should be . Anybody know where parts are available from
Thanx Dixie
       Post #: 1
old Quadra? - 2/22/2002 9:58:28 PM
kevin mcgrath
Status: offline
Sounds like one of the original Quadra 35s.....
Try [url]WWW.bennettbuilt.com[/url]
They know all,and have all if anyone does for Quadras...
_____________________________
Kevin
MAAC 6401L,CD.
(in reply to Dixie)
       Post #: 2
old Quadra? - 2/23/2002 9:33:27 AM
Ernie Roberts
Status: offline
hi dixie .. don't know which quadra model you have but you can reach quadra at the following tel no.
613-264-0010
company is called 'aerrow' and they build the quadra's .. they are in perth ontario canada ..
take care .. e.
(in reply to Dixie)
       Post #: 3
old Quadra? - 2/23/2002 6:36:33 PM
kevin mcgrath
Status: offline
Ernie is quite correct about the current Quadra contact but B&B stock the parts you are looking for and I doubt the factory does.B&B handle US warranty for Quadra too......The engine you have is probably a senior citizen,and not produced for some time.......
Kevin
MAAC 6401L,CD.
(in reply to Dixie)
       Post #: 4
Old Quadra - 2/24/2002 12:37:51 AM
rcign-RCU
Status: offline
Quadra made an 80cc years ago..It has a chainsaw case with the carb on the side of the case, not the cylinder..Rear exhaust..If the plane is a 25% the 80cc would be a little large for it ...
There's a 10 foot Stearman in mexico with one on it..Flies well...
(in reply to Dixie)
       Post #: 5
old Quadra? - 2/24/2002 4:05:35 AM
Dixie
Status: offline
Thanx guys I appreciate the info. anyone know the fuel mix 30:1 or something else. I also need the point gap and coil gap also horsepower would be nice.
On a different note a friend of mine picked up a raven and was wondering if anyone knows the CG for this aircraft
thanx alot
Dixie
Southern ontario flyers
Leamington
(in reply to Dixie)
       Post #: 6
old Quadra? - 2/25/2002 10:26:47 AM
Ernie Roberts
Status: offline
hi dixie .. can tell you the gaps for the 35, but don't know if they were standard for all the point equipped quadras .. points normal setting .. .015(15 thou) .. can be opened to about 20 thou to increase rpm .. but engine gets harder to start the more you open them .. normal coil gap from flywheel .. .010(10 thou) ..
gas/oil mix depends mostly on the 2 cycle oil you're using .. i run about 30 to 1 on my 35 .. guess i could go higher but never worried about it too much .. btw aerrow/quadra does stock some old parts .. i've changed my crank a few times as a result of improper landings(sometimes called crashes) ..
take care .. e.
(in reply to Dixie)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.641RCU4
