mroos
Joined: 12/25/2005 From: Oberdiebach (near Mainz), GERMANY Status: offline
Hell Dan, the current rules (Volume F3D) on my Website : http://www.q500.org/regeln/sc4.f3d.07.zip All other parts of FAI rules have to be considered also (most important Volume ABR, general section). Each NAC of a country translates the rules into their foreign language, but the original FAI Documents are mandatory. "5.2.12.11 The Contest Director has the right to request any competitor to make a flight to demonstrate the airworthiness of his model aircraft and/or ability to fly the aircraft around the course. If during the race, the Contest Director considers any model aircraft to be flying erratically, dangerously, or so low as to endanger Course Officials, he may disqualify the competitor from that heat or from all heats and require the model aircraft to be landed immediately. Persistent flying below the top of the pylons shall be considered dangerous. After passing the first pylon on the first lap of the race, flying below the top of the pylon will result as one infringement. Two or more infringements during the same heat shall cancel the flight." "5.2.12.4. [...] The sideline judges will record as an infringement any over flight of the sideline and any flight below the height of the pylon as stated in rule 5.2.12.11." General section makes clear, that flying below means, a part of the airframe is below (Pylon( usually 5m. It doesn't mean a part of the airframe must be above pylon to get no cut. What is in your opinion unclear ? Throwing parts at an offical or verbal slander lead to disqualification (general section). General section and Volume ABR also applie to To F5D, and all other FAI classes. best regards, Mario
< Message edited by mroos -- 6/28/2007 10:35:01 AM >
_____________________________
Mario - www.q500.org "If everything seems under control, you’re just not going fast enough." Mario Andretti
