RE: KMP Beechcraft Bonanza's!
Tower Hobbies
Logged in as Guest
  Printable Version
Hangar 9 Cherokee 40 - RTF
Seller:  Dumb Thumb
Details:   $300.00   |  8/25/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: KMP Beechcraft Bonanza's!
Page: <<   < prev  1 2 [3] 4 5 6   next >   >>
Login
RE: KMP Beechcraft Bonanza's! - 5/24/2008 10:43:40 PM
SLONLOW
Status: offline
OK sorry here we go. Here You can also see the airlines I had to use because I did not have enough of the original ones that came with it. I made some very small holes in the wings to pull them thru along with the servo leads. This must be done before joining the wing halves together. You can also see the tubes used to hold the Elevator stabs onto the fuse. Very rigid. Very nice. Make sure you run some 60 grit sand paper over them before glueing in so that they dont come off.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to SLONLOW)
       Post #: 51
RE: KMP Beechcraft Bonanza's! - 5/25/2008 2:33:34 PM
M64
Status: offline
very smart!
_____________________________
You can't change what you don't acknowledge.
       Post #: 52
RE: KMP Beechcraft Bonanza's! - 5/25/2008 5:40:37 PM
khodges
Status: offline
quote:
ORIGINAL: AKondor
Personally I think the V-tail has the cool factor going for it and would be different from all the other models at the field.
I agree. The V-tail is the REAL Bonanza. The standard tail is sort of like a Porsche with the engine up front. Sure, they made them, but.....
I also agree with whoever stated, put tip tanks on at least one version, maybe the V-tail. What is the cowl width? Would one of the newer 50cc gas twins work without having spark plugs sticking out?
Club Saito #2, WACO Brotherhood #20. What other trouble can I get into?
(in reply to AKondor)
       Post #: 53
RE: KMP Beechcraft Bonanza's! - 5/25/2008 9:43:26 PM
SLONLOW
Status: offline
The space allowed for engine placement is very small. About 7 inches width by 4.25 high at the point where the engine should be. You lose about 2 inches when the cowl goes over the nose of the plane. So its a narrow space. Over the 7 inches and the engine heads will stick out the sides of the cowl. Im setting my engine back close to the firewall thus I will need to make a special adapter for the shaft to bring it past the nose as I did with my 182 when I used similar engine. I dont forsee any problems.
Click for fullsize
Click for fullsize
(in reply to khodges)
       Post #: 54
RE: KMP Beechcraft Bonanza's! - 5/26/2008 4:31:44 PM
M64
Status: offline
I think a 50cc twin will be way too much for this size plane, thats including weight and power.......
just my 2 cents
       Post #: 55
RE: KMP Beechcraft Bonanza's! - 5/26/2008 6:25:55 PM
molyhotdog
Status: offline
It may be better to put the engine farther forward, or at least try some preliminary balancing before mounting. You most likely will need to add a substantial amount of nose weight. That was my experiance anyway.
On another note I was at a funfly this weekend and even standing in my trailer the Bonanza draws quite a bit of attention. I'd didn't take it out as it was very windy.
(in reply to M64)
       Post #: 56
RE: KMP Beechcraft Bonanza's! - 5/26/2008 8:00:59 PM
SLONLOW
Status: offline
I dont doubt I will need to add a bit of nose weight but the engine is heavy enough. On my 182 I ended up putting my two battery packs next to the firewall. NO additonal weight was needed. I will be using twin packs on this one as well. I will be mounting the engine and balancing before I have to cut the cowl or anything else. I just hate adding dead weight to any plane. YUP the 50cc twin would be too much..plus you have to consider prop clearance as well. I will most likely be using a 13 x ? 3 blade. If a 14 clears then I will use my 14x6 3 blade. I'll keep all posted. I have not heard of anyone else having one or even seen a video as of yet on any either V or T tail...
(in reply to molyhotdog)
       Post #: 57
RE: KMP Beechcraft Bonanza's! - 5/26/2008 8:25:26 PM
SLONLOW
Status: offline
Molyhotdog, can you post pics of yours. Did you purchase the all composite as i did along with the retracts? What engine is in yours?
       Post #: 58
RE: KMP Beechcraft Bonanza's! - 5/29/2008 6:07:06 AM
molyhotdog
Status: offline
I bought one of the very first ones. At that time the composite and retracts were included in the price. The price has changed with the different options.
I installed the RCV 120 as recommended by the owner of KMP but that engine wouldn't get the plane going fast enough for it to lift off the 900 foot grass runway at our field.
A friend had a used Moki 1.8 that I bought and put on it, it flies great now and certainly does not seem overpowered.
I've never posted pictures on here but will try in the near future.
Andrew (KMP), I'm still waiting on the landing gear door hardware to show up at Pauls Model Supply, Fargo ND so I can finish my plane. PLEASE send it soon as its been at least 6 months now that I've been waiting.
       Post #: 59
RE: KMP Beechcraft Bonanza's! - 5/30/2008 5:35:03 AM
molyhotdog
Status: offline
Here's some quick pics of the fuse and some of my other planes.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 60
RE: KMP Beechcraft Bonanza's! - 5/31/2008 7:51:19 PM
SLONLOW
Status: offline
Hehehehe, That Moki and muffler sticking out like that really look funny, bet it takes off in less than 200 feet now!!!! Just finished programming my AR7000. Still need to install engine. Will install the Elevator stabs today. For an ARF this is taking me a long time I know.
       Post #: 61
RE: KMP Beechcraft Bonanza's! - 6/2/2008 9:10:51 AM
molyhotdog
Status: offline
The Moki wouldn't go horizontal, seemed to look like a tractor pulling rig vertical so I lined it up with the v-tail. It still takes quite a bit of runway to lift off though. I moved the motor a little farther forward tonight and put the receiver battery in the engine compartment and was able to trim some lead and get the plane to balance at around 19 pounds.
       Post #: 62
RE: KMP Beechcraft Bonanza's! - 6/2/2008 4:29:29 PM
SLONLOW
Status: offline
19Lbs..HOLY COW!!! Now you are making me wonder if my 160twin will even move this plane. It pulled my 13lbs 150 around with ease, and my other twin pulled my Hanger 9 182 ok with good climb rate....but it was only at 17lbs. I might have to go to a 182 twin...I'll start looking for one now,,,,even if I dont use it, I still have a 1/4 scale Cub I can use either on..
       Post #: 63
RE: KMP Beechcraft Bonanza's! - 6/4/2008 4:07:37 PM
adetoyinbo2
Status: offline
hi all
i just finich my lastweek i installed ax120 os engine in mine.would this engine be enough to fly this plane.
thanks
jimmy
(in
