cristini
Joined: 9/18/2008 From: Pretoria, SOUTH AFRICA Status: offline
Hello, I have been flying the bonanza for the past three weeks Here are informations that might be useful for somebody who is willing to buy this aircraft The engine i use is an OS120 AX (two stroke) with the original muffler, everything is enclosed in the cowl , i had to do some modifications for that solution if you want the pictures i'll post them. I am flying with the composite wings and to achieve the correct CG 430grams of lead were added at the front. I am using the kmp retracts, they were all leaking including the valve that comes with them . look is nice but quality wise... It toolk me two hours of work to achieve the modifications for the engine to fit properly inside and to strengthen the front. The aircraft is flying very nicely and is easy to land also i found her a bit nose heavy , she is very stable in the air and look remarcably scale The trap doors are glued to the struts with standard silicone, it works 100 % and had a bit of flex The amount of up and down for elevator and ailerons had to be reduced by 50 % otherwise it is way to sensitive
