RE: Eflite Edge 540 BP 3D ARF - Comments??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Eflite Edge 540 BP 3D ARF - Comments??
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/1/2007 12:21:36 PM
rednote
Status: offline
Wow, I'm really happy to find this thread...just picked up the 540 BP and can't wait to get it in the air now that I've read all the great comments. I not a great 3D pilot, but I'm practicing like crazy on Real Flight G3.5. I plan to hand launch my Edge and land on tall grass, that's my only option for and airfield right now. And from what I've read, the landing gear that come with the kit aren't worth putting on.
Should I go with a folding prop for now since I'm landing on tall grass? Any advice would be great.
I'm also looking for a new radio that's got expo, and advice on that would be welcome. I'm using a 5 year old JR 6 channel, it's been a good companion, but I'm guessing that I need expo if I'm going to be learning 3D moves.
Thanks!
Rod
< Message edited by rednote -- 10/1/2007 2:08:01 PM >
(in reply to tcclong)
       Post #: 26
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/1/2007 10:31:15 PM
mflander
Status: offline
Put mine together on sun. Flew like crap... I thought I had the CG just right with it, turns out I did not. Battery placement is very sensitive with this one. I re-cg'd it last night, and will do its second maiden tonight.. more to come!
(in reply to Always flying)
       Post #: 27
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/2/2007 2:31:09 AM
rednote
Status: offline
Too bad about your CG troubles. Please share your CG placement...what's your set-up?
(in reply to mflander)
       Post #: 28
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/2/2007 2:52:00 AM
tcclong
Status: offline
Yeah, this plane is very sensitive to the battery placement. I put 3 strips of velcro side by side just in front of the wing. The battery was mount vertically. This allowed me to move it about .75 inch forward and aft to find the best spot. It gets pretty squirrely if you put the CG aft very much. But that can make it more fun if you know what you're doing. I think it's a great plane to practice 3D stuff. It is, however, a profile plane, so it doesn't handle quite as smooth as a full fuse plane.
(in reply to rednote)
       Post #: 29
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/4/2007 7:31:34 PM
RCB757
Status: offline
E-Flite Edge 540 BP Landing gear is made of soft alumimum and will hardly support the weight of the airplane.
I called Horizon Hobby Tech support and spoke with Rusty on 10-04-07. Rusty advised me that the landing gear is "adequate" for the airplane, however it will not take much abuse. I explained to Rusty that the main landing gear needs to be redesigned because it will hardly hold the weight of the airplane up and bends badly with even the smoothest of landings. Also after reviewing some comments on the landing gear on RC Universe, I was not alone.
Rusty did not agree with me at all and said that once one person complains about something on the web sites, everyone chimes in. Of course people are "chiming in" because there is a design problem with this landing gear.
Rusty finially resolved the issue by offering to send me a new set of landing gear legs. I guess I will just use these gear legs to make a new set out of better material.
E-Flite makes some fine products and I have and will continue to purchase their goods, however they missed the mark on this landing gear and really don't plan on making a stronger replacement.
       Post #: 30
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/4/2007 9:35:21 PM
tcclong
Status: offline
Well, "Rusty" has apparently never tried to land one of these with the stock gear. Like you say, even on a slightly non-perfect landing you will bend the gear. I actually bent mine and bent them back so many times that the gear finally snapped off. I agree with you that everything is great on this plane except the gear. On another one of Eflite planes that is about the same size, the Tribute FX, the landing gear is great. It is a steel wire gear which works perfectly. You can land just about as hard as you want and the gear just springs right back. Just like the gear on an Airfoilz - works perfectly. I am guessing Eflite uses that aluminum gear on Edge 540 because it bolts onto a flat surface. This would be a little harder to accomplish with a wire gear, but not impossible.
Another drawback to the very soft aluminum gear is that is doesn't protect the plane. I broke the motor mount stick several times from hard landings because the gear did almost nothing to absorb thelanding. They just immediately spread and allowed the prop to hit the ground. Changing to a different gear on this plane would be a wise move.
(in reply to RCB757)
       Post #: 31
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/4/2007 10:32:36 PM
IFlySlowPlanes
Status: offline
I've had my 540BP flying for a few weeks now and absolutely love it. I don't do any 3-D with it at all (lack of skill being the limiting factor here), but wanted something fun to fly in the local parks. What's been said already about the gear, I won't repeat, except to tell "Rusty" that he needs to take the blinders off when it comes to seeing the problem for what it is. Mine lasted one landing...one. Bent like a pretzel. The aluminum could not be any softer unless it was still in the forge at 1100 degrees. Took it off and have flown just fine without it ever since.
As to balance issues, yes, it does seem extremely sensitive to battery placement. I first set my CG at the recommended 4.5" but it was WAY to twitchy there for me (maybe you 3-D guys like it better that way, but I got tired of my knees knocking. Moved it forward about 1/4" and suddenly it's tame as can be when I want to putz around, and still plenty wild enough to impress the local kids with my flipping and flopping (I tell them it's aerobatics, see, and they, having a mere public school education, believe I am good at it).
Breaking with apparent tradition, I used a brushless inrunner through a gearbox (left over from my not-so-dear-departed 3-Buddy Yak profile). I get unlimited vertical and fly around at half throttle much of the time. broke the motor mount stick once by flying in circles around myself lower and lower until I equalled the low-altitude record, caught a wingtip, and cartwheeled the thing. Wasn't going too fast, so the damage was limited to the motor mount. A little epoxy and we're back in business.
I hope to have this one for many seasons to come. And if I wreck it, I'll defintiely get another. Terrific little plane.
       Post #: 32
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/5/2007 12:43:07 AM
FlooredCOBRA
Status: offline
This plane is extremely addictive and thats a fact! I find myself flying pretty much every day after work in the front yard. That is main reason why I bought it in first place. I dont have to load up anything just charge battery and go.
I messed around with the CG and found my sweet spot. I just took a permanent marker and made a line where the battery should line up and place it there. It is fast easy way to slap the battery on and knowing where your CG is at.
Well I am back in the air after messing around with speed control problems. But on my last flight motor cut off and plane belly flopped to ground while my gear did the split. I tried to bend back but one of them broke off. That poor thing could only be bent back so many times.
I now been debating on how to correct the gear problem. I like having gear because I like taking off from the street but besides the stock gear what else is there to do? Are there any to purchase out there that would fit? I plan to make some myself but would like to see what u guys are coming up with also.
_____________________________
Revver Brother #79
(in reply to IFlySlowPlanes)
       Post #: 33
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/5/2007 2:00:29 PM
rednote
Status: offline
I'm thinking about using some JR NES 241's or should I go with the recommended E-Flite S75s instead? I don't really want to throw another $75 into the fire at the moment
-Rod
(in reply to FlooredCOBRA)
       Post #: 34
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/8/2007 3:37:31 AM
TOYMAKER
Status: offline
The l.gear on this plane has to one of the worst I have seen on any kit I have built since the seventies. I threw the gear away after the first day of flying. I bolted the wheel on the fuse where the gear was bolted and just hand launch it. Havent broken a prop yet belly landing it. A set of c.fiber gear woulld be ideal. Plane flies nicely and does flat spins that can be held just three feet off the ground.
Dont use cheap servo's(BTDT) had some bluebirds(crap servo's) and switched to HS55's and the plane flies good now. Before when I would push hard in a loop the plane would try to roll out. It was a combination of one wing tip being slightly heavy and the aileron servo's where blowing back. Problem went away after replaceing servo's and balancing tips.
AXI 2212/26 Pheonix 10 controller 10x4.75 APC 1320 dualsky bats HS55 servos
Wayne G.
quote:
ORIGINAL: rednote
Thanks!
Rod
< Message edited by TOYMAKER -- 10/8/2007 3:43:16 AM >
       Post #: 35
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/9/2007 9:36:56 PM
mytjbend
Status: offline
I just ordered carbon fiber landing gear for my 540 from atlanta hobby. They are made for one of their balsa profile planes and cost about 15 bucks, I'll let you know how they work out. By the way I am new to this forum site and this is my first posting, so forgive me if I can't get pictures up right away and all that stuff. C'YA!!
(in reply to TOYMAKER)
       Post #: 36
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/13/2007 4:38:05 PM
Han2007
Status: offline
Would this plane work for indoor flight in a gym? I've got a hacker 20-22L with some thunder power 1320 milliamp batteries looking for home.
(in reply to mytjbend)
       Post #: 37
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/14/2007 4:59:32 AM
mytjbend
Status: offline
Ya, I think the hacker is lighter and has about the same power as a park 450. As for indoor flying I'm not experienced enough to trust my flying in a confined area yet, but it does have the characteristics for it, in the right hands. I'm still learning close in flying and 3d handling, so your best bet is to ask a more experienced pilot before trusting my opinion. Good Luck!
(in reply to Han2007)
       Post #: 38
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 10/17/2007 3:24:44 AM
