RE: Eflite Edge 540 BP 3D ARF - Comments??
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> RE: Eflite Edge 540 BP 3D ARF - Comments??
Page: <<   < prev  1 2 [3]
Login
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 3/28/2008 12:23:31 AM
Stormovic
Status: offline
No need to use a folding prop if landing in tall grass. I fly a Yak 55 profile from a field of tall grass,hand launch and full stall landing into tall grass with no problems.
(in reply to chips303)
       Post #: 51
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 3/30/2008 9:32:08 PM
jmir
Status: offline
quote:
ORIGINAL: mstcitabria
P47Tbolt,
Thanks for the DuBro landing Gear suggestion, perfect fit for the Edge and more clearence for the 450 motor 12/6 prop. Easy to mount the wheel pants too....
http://www.shopatron.com/product/part_number=943/101.0
I'm currently building the 540 and, based on comments on this forum, I reinforced the landing gear with regular wired expoxied to it. It seems very strong now. I have not flown the plane yet but I don' think I will have any problems with it. See attached photos. By the way, I put on slightly bigger wheels without the pants since I take off and land on a grassy field.
I have a question about the CG. Instructions say that it should be 4-1/2 inches from the leading edge. Mine balances perfectly at 4-1/2 inches..... but WITHOUT THE BATTERY!! I have to assume that it is supposed to balance at 4-1/2 with the battery mounted so mine is way too nose heavy.
I do have the Park 450 motor installed instead of the 400 which is a little heavier and it mounts a little forward compared to the 400. However, there is no comment about it in the instructions.
Did any of you have any problems coming up to the 4-1/2 CG point??
Any help will be greatly appreciated.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Not raining? Not too windy? Guess what I''m doing!
(in reply to mstcitabria)
       Post #: 52
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 4/2/2008 3:25:11 AM
jmir
Status: offline
Well, I did not have much time, but I just couldn't wait any longer even though today was a very windy day.
The wind was blowing well over 15 mph, so I was not able to trim it. I'll have to wait for a calm day for that.
I finally got to balance it at the recommended 4-1/2" point without adding any weight. I just had to place the ESC and the battery underneath the wing, behind the landing gear.
Using the Park 450 outrunner gave it plenty of power against the wind. I was able to take off from the ground in just a few feet. Did a few circles, rolls, loops, knife edges, etc -- however, not very pretty because of the wind. Landing was a little more intense because of the wind, but I was able to control it well and landed it "elevator style".
I'm going to really like this plane. I think it will be a great 3D trainer, so I hope to be moving on from 2-1/2D to 3D soon.
(in reply to jmir)
       Post #: 53
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 4/8/2008 3:42:33 AM
dutchalltheway
Status: offline
Hey guys, I'm eye-balling this Edge as well. Can any of you guys tell me how much flight time you get out of your set up please?? I'm kinda curious about that. Thanks so much in advance.
Hanger: Twist .40 ARF, FuntanaX50 ARF, OMP Katana V2 .46 ARF
(in reply to jmir)
       Post #: 54
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 4/8/2008 8:51:46 PM
mstcitabria
Status: offline
Heard of some flights over 20 minutes and others getting 12 to 15 minutes depending on the type of flying. This is with the Park 450 and Thunder Tiger 1320 3 cell Li Po set up.
Mike T.
(in reply to dutchalltheway)
       Post #: 55
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 5/7/2008 8:27:37 PM
Julian Maza
Status: offline
hey i have a e-flite park 480, do you think that will be too much?
       Post #: 56
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 5/8/2008 5:46:07 PM
tcclong
Status: offline
Yeah, the park 480 is definitely way more power than you need. The plane will be very nose heavy, and will fly heavy overall if you use that motor and a battery than can drive it. I would think it would also be tough to get it mounted to the motor mount. That being said, I believe there are some that have done it. I know there is one guy that mounted A123 batteries on his (which is a lot heavier than Li Poly) and he flew it around alright. If you search around on the forums you should be able to find that.
(in reply to Julian Maza)
       Post #: 57
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 5/13/2008 4:03:00 PM
HUNTERANDJEFF
Status: offline
I have found that mine flys a bit better heavier. Tracks better at least and I am still able to hover it. this plane is very manuverable and it is a blast to fly - even in the wind.
Here's what i have in it.
Axi 2814-12 gold
Castle Creations 35 amp esc
2100 mah Thunder power battery
HS 65 servos
Castle creations 7 channel RX micro
Jeff
JeffThe only yard sales I go to is when I pick up my plane from all over the runway!!!!
Revver bro #191
(in reply to tcclong)
       Post #: 58
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 8/6/2008 12:30:12 AM
OkieTrucker
Status: offline
Hi guys, i need some help. I am thinking of buying this plane for the following gear I have, and I just want to know if this gear will fly it: Electrify Rimfire 28-30-950kv (PN# GMPG4560), Electrify 25a brushless sc (PN#GPMM1820), and Electrify 1500 MAH, 11.1v 20C (PN#GPMP0613). I am brand new to electrics, and any help you give me would be great!! Thanks and happy flying
"A veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The ''United States of America'', for an amount of ''up to and including my life.''" (Author unkn
       Post #: 59
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 8/11/2008 4:30:26 PM
tcclong
Status: offline
Okie,
Looks like you have a setup that will work alright. That motor will provide 150W, which is what you want. For 3D flying, you want at least 150W per pound (I personally prefer closer to 200W/lb), and this plane comes out to about 1lb. If you haven't already bought the motor, I would think about the 750kv version. That will give you more torque at the expense of speed. The lower kv motors also tend to consume less watts, so you get longer flying times. If you use a 11x3.8 Slowfly prop with this motor, you will get outstanding torque and a large prop wash, which is perfect for flying 3D. You want to fly low and slow!
(in reply to OkieTrucker)
       Post #: 60
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 9/11/2008 5:39:49 AM
leveehog
Status: offline
Was looking for a small front yard 3D plane and I tried to purchase this model from Horrizon Hobbies today. They have raised the price nearly 40% from that posted in their catalog. Price increased from $89 to $119. It states prices are good through Sept 30, 2008. Was very disappointed since it seems much more than inflation.
       Post #: 61
RE: Eflite Edge 540 BP 3D ARF - Comments?? - 9/11/2008 12:48:52 PM
OkieTrucker
Status: offline
I think they got popular and that made them raise the price. My LHS has one for $74.99, I guess I better go get it.
(in reply to leveehog)
       Post #: 62
Jump to:
