flyinrog
Joined: 9/3/2002 From: Burlington, NC, USA Status: offline
quote:
ORIGINAL: 3DownLow A glow version, forget it! You'll not get one dimension out of me...naw just kidding! If you are going glow, are you planning on using balsa or foam? If it's foam you'll have to seal everything, glow fuel melts this foam like a marshmellow on hot fire. And the smaller prop diameter isn't going to help out with 3D stuff either. A 13 x 4 seems to be the best size prop for this size Clik. I'm making a beefed up version for my buddy with LG and a paint job. If you send me your e-mail address I'll send you what I've got as long as you abide by the David K.'s (the designer) wishes. Or go to RCGroups.com and look under "Indoor Pattern/F3P" section for the Clik prototype and check out post #312. All will be revealed. I fly 1/2A and have a friend who makes smaller versions with the depron foam and flys them with diesel! Once I got that crap on my hands I knew I never wanted to bother with it...I like glow and electric, most foam is fuel proof it just doesnt take long to make it look like crap,, I have taken $3 foam gliders and put .049 engines on them and they fly fine and last forever...I am new to brushless stuff, had a few GWS planes/motors and they were very instrumental in my learning to fly...I'd just like a giant foamy/glow to play with...Rog will pm you with email.....
_____________________________
Ever walk into a room and forget what you went in for?...ADHD, welcome to my world,it happens everyday!
