alanc
Score: 105 Joined: 12/15/2003 Last Login: 5/25/2013 From: manchester, AE, UNITED KINGDOM Status: online
er, crossly, stop giving the colonials our secrets these funflys are a straight copy of the magic, made with the permission of the uk importer, who the 2 champions who are mentioned fly for the fuselages are a box structure, shaved to shape, and sanded until the light from a 12volt bulb, dangled down the fuzz can be seen through the wood, then cyno is sprayed from the bottle on the fuselage insides, to toughen them up, never had a brake yet the tail and flying surfaces are from 3/16 soft/medium sheet all strips being cut from the same sheet for each surface, the wing ribs have MINIMUM sheeting, have a good look at the wing spars, look strange? yes they are, they are t shaped carbon spars .020"thick, rips have just a slot cut in for the upright of the t, one on the top, one on the bottom gives a girder efect, never had a break there either, this year, all the tailplanes and ailerons are being replaced, not because of warping, but because of damage sustained, the tailskid is interesting, ever wondered what to do with those large futaba discs you get?? cut a slot in the fuzz underside, insert disc, and cyno, bit of baking soda, as a fillet, and there you are, one skid, wear it out, get a pair of pliers, twist it a bit, turn it round, glue it again engines are os32sx with weston throttle pipes, you guys should really try these they are from the company that imports the magnum in the uk the all up wight of the aircraaft is just under 3lbs, radio is a mini,lying down for the throttle, and standard 3001s for the rest, closed loop is used throught for control surface actuation, they have given good service but i think that this tear, the lads are retirng from fun fly, and concentrating on display flying have a good 2004, may all your landings be upright
Hide Signatures
