RE: FSA Gallery
Tower Hobbies
Logged in as Guest
  Printable Version
Extreme Flight Yak 54 - 87 - ARF
Seller:  mononpro
Details:   $1,150.00   |  11/19/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> RE: FSA Gallery
Page: <<   < prev  1 2 3 4 5 6 7 [8]
Login
RE: FSA Gallery - 5/29/2008 2:25:56 AM
rotorheadbob
Status: offline
Roger,
Will you bring that and the others to the Airplanes of the World? Great looking airplane!
Rob
(in reply to RFarley)
       Post #: 176
RE: FSA Gallery - 5/29/2008 11:16:18 PM
weathervane
Status: offline
It is a .40 size plane. The plane is an old (1980's) GoldBerg kit.
Congratulations on the article in Model Aviation.
-Andrew
quote:
ORIGINAL: RFarley
What scale is that Cub?
I've just finished a 1936 Monocoupe 110 Special... here are some pixs
_____________________________
With out trucks, America stops.
www.freestateaeromodelers.org
       Post #: 177
RE: FSA Gallery - 5/29/2008 11:44:33 PM
weathervane
Status: offline
My new ride. I needed more room for more planes.
-Andrew
Click to see fullsize image.
Click for fullsize
(in reply to weathervane)
       Post #: 178
RE: FSA Gallery - 5/31/2008 3:38:48 AM
RFarley
Status: offline
Yes, I should be bringing the Monocoupe to the fly-in as well. It had it's maiden flight Thursday, and came back in one piece (although the left rudder cable came loose 'cause I forgot to safety wire it). Since the tail is scale size (small), it flys a little quirky under power, and it also floats a lot at touchdown being so light (10 lbs, 25 oz/ft^2). Got to remember to manage the energy on final. The OS91 4-cycle sounds really throaty, very realistic!
I'm going to find a way to strap the Monocoupe fuselage to my car roof because I have no room left in the car. That nice big green truck looks just perfect to transport just about anything!
I sent in the picture of the DH-84 to Model Aviation about 9 months ago for Focal Point, I thought they had passed it over. I guess there is a long line!
(in reply to rotorheadbob)
       Post #: 179
RE: FSA Gallery - 6/1/2008 10:45:58 PM
weathervane
Status: offline
Our spring cook out. A good time was had by all.
-Andrew
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 180
RE: FSA Gallery - 6/7/2008 3:58:30 AM
thunder21
Status: offline
Here's a picture of Jake with his new plane. I was flying form the box next to him and heard him say, "This is the first day I've flown the model and I'm not doing any aerobatics with it." And a few seconds later he said "I just did an axial roll!" Great to see you back again, Jake.
Click for fullsize
       Post #: 181
RE: FSA Gallery - 6/7/2008 8:15:48 PM
thunder21
Status: offline
Here's a video of my B-17.
http://www.glue.umd.edu/~markt/B-17.wmv
(in reply to thunder21)
       Post #: 182
RE: FSA Gallery - 6/7/2008 9:26:42 PM
weathervane
Status: offline
It looks good guys. The plane looked real nice in the air.
-Andrew
       Post #: 183
RE: FSA Gallery - 6/8/2008 8:37:09 AM
thunder21
Status: offline
Here's Sam doing a "Valley Run" and Steede doing a vertical landing.
http://www.glue.umd.edu/~markt/Valley_Run.wmv
       Post #: 184
RE: FSA Gallery - 6/8/2008 12:29:45 PM
weathervane
Status: offline
Ouch.
       Post #: 185
RE: FSA Gallery - 6/8/2008 2:56:00 PM
kpm
Status: online
Nice video! Thanks Mark. I was beside myself showing off for the camera like that
That valley run was fun. Even though the Alpha disappeared behind the trees, I think I need to push it down another 10 feet after clearing the runway and entering the valley
Steede did the V. run and brushed a tree. He landed and had leaves stuck on his plane. I think I am done doing that. Too risky!
quote:
ORIGINAL: thunder21
Sam
       Post #: 186
RE: FSA Gallery - 6/8/2008 8:43:02 PM
Jlevin
Status: offline
He he he, I'm not gonna deny it...I did pull an axial roll for a second there, and it was one of the smoothest-feeling rolls I've ever flown (it was a bit wobbly up-and-down, but as far as rotation went, it was real smooth)! That plane flies like it's on a rail; I can't wait to see what it can really do once I get a bit more "in tune" with it!
Technically, that was the second time I'd flown the Edge; the first time I took it up, I had 100% throws dialed in as the low rate, and quickly found myself bringing it back in so I could adjust the throws to a more flyable level. Note to self: check your throws before maidening a plane!
Jake
"You can put wings on a pig, but you can't make it an eagle"
       Post #: 187
Jump to:
