H9 1/4 Cap 232 assembly help.
Tower Hobbies
Logged in as Guest
  Printable Version
The JETLEGEND L-39 (3 COLOR SCHEMES) We now offer building......... FREE S&H In U
Seller:  FlyingboyD
Details:   $2,600.00   |  10/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> H9 1/4 Cap 232 assembly help.
Page: [1]
Login
H9 1/4 Cap 232 assembly help. - 2/23/2002 12:10:57 AM
Timbersnake
Status: offline
Howdy people...I'm getting ready to 'assemble' my 1/4 Cap (got an OS 1.6fx w/ bisson pitts...whoohooo!!!) and I'm running into some firsts for me. I've put together quite a few Arf's but have never sealed my hinge lines. I understand the reasons for sealing, and the general idea, but how do you do it? The one method I have heard seems a little arduous...it is to take a piece of clear tape, fold it down it's length, move the control surface (aileron, elevator, etc) to it's furthest point, and lay the tape into the gap, press it in, and cut off the excess later. Is this right? Is there an easier way? I also vaguely recall reading an article whree a guy ironed a small strip of covering to the wing and let it lay flat on the aileron..(didn't iron it to both surfaces...allowing the aileron to move)
Next question...The instructions for the CAP say to use standard servos. Can I get away with this? Thanks.
Tracy Mettler, Ketchikan Alaska
       Post #: 1
Sealinf Hinge Lines - 2/23/2002 12:46:52 AM
Rocketman612
Status: offline
I have done this to most of my planes. I use a strip of covering open the gap as far as it will go and iron both surfaces. You should get full movement and a good seal. Pete
(in reply to Timbersnake)
       Post #: 2
H9 1/4 Cap 232 assembly help. - 2/23/2002 2:13:07 AM
TiGuy
Status: offline
Ditto to rocketman. I've done it with tape and covering. Tape works, but....it's a major pain compared to covering, and it usually ends up peeling off too. I like to use a low temperature covering to help eliminate bubbling, but it doesn't come in clear. Go get a roll of clear monokote just to have around for sealing hinge gaps.
       Post #: 3
Re: H9 1/4 Cap 232 assembly help. - 2/23/2002 4:33:17 AM
JBH
Status: offline
[QUOTE]Originally posted by Timbersnake
Next question...The instructions for the CAP say to use standard servos. Can I get away with this?[/QUOTE]
On the throttle... but even there I wouldn't. :-) Go for some servos with at least 70oz of torque for the ailerons and elevators (80-100 all the better). Hitec 5645s are not toooo expensive, but you could go all the way down to 605s. But, you'll want something beefier for the rudder.
I prefer JR servos... but they're more expensive.
       Post #: 4
H9 1/4 Cap 232 assembly help. - 2/24/2002 3:29:04 PM
wildthng
Status: offline
I use 605s every place but the rudder.there i use a 615 metal gear.Use a 5cell rx pack and the 605s put out over 90 in lbs(acording to my dealer)seal all surfaces(i use clear ultra coat),good luck
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU5
