Air wild 29% extra hovering help
Tower Hobbies
Logged in as Guest
  Printable Version
Rich Model 35% Extra 260 - Add engine & rx - ARF
Seller:  ScaleFreak
Details:   $1,500.00   |  11/21/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Air wild 29% extra hovering help
Page: [1]
Login
Air wild 29% extra hovering help - 6/24/2007 6:08:54 PM
Zman39
Status: offline
Hey all,
I recently put together a extra 260 from airwild with DA50. The plane flys great but I am having two problems, both related to hovering the plane. The first is it requires a lot of up elevator to keep nose up so consequently my hovering is bad because I am constantly fighting the nose. Is this a sign of nose heavy or just a normal thing with the bigger planes compared to the .40 size nitro planes. Second problem is when I come in to enter into a hover, the plane consistently wants to tip stall and drops a wing causing me to start off with getting it back under control. Not sure if I entering the hover wrong or what but for me to hover close to ground, I have always brought it in low and when ready pull back and apply throttle as the nose goes up.
Any help appreciated
Z
       Post #: 1
RE: Air wild 29% extra hovering help - 6/24/2007 6:17:25 PM
krayzc-RCU
Status: offline
has the plane been lat. balanced?
how does it fly inverted?
how does it track on up lines?
_____________________________
smooth as silk!
(in reply to Zman39)
       Post #: 2
RE: Air wild 29% extra hovering help - 6/24/2007 10:13:20 PM
Zman39
Status: offline
quote:
ORIGINAL: krayzc-RCU
Hello,
The only balancing I did on plane was getting the cg in range. Not sure how to lateral balance.
Flys well inverted and with hands off it slowly starts heading toward ground.
In straight up vertical, full power, it goes almost straight maybe needs just a touch of right rudder. One thing I didnt mention is that it tip stalls when I pull back hard on elevator to enter the hover, otherwise the stalls are fairly gentle.
(in reply to krayzc-RCU)
       Post #: 3
RE: Air wild 29% extra hovering help - 6/24/2007 10:20:48 PM
krayzc-RCU
Status: offline
work out all trimming issues so that you are not fighting the plane....
http://www.mini-iac.com/Portals/57ad7180-c5e7-49f5-b282-c6475cdb7ee7/PGoldsmith%20on%20trimming.pdf
smooth as silk!
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.422RCU5
