akular1
Hey everyone, This website is a wealth of information, and I'd like to thank everyone for their help. Unfortunately, I have come across another situation with the landing gear on this airplane. One side of the gear is fixed in perfectly after I tighten the screws to lock them down. The other side of the gear, however, is still very loose after I have tightened them down. I noticed that there are 4 openings at the bottom of the airplane to allow me to view the screws. I think its important to try and get nuts tied on the back side of the screws. The only problem is, I dont have a screw set tight enough to get into the holes! A locknut itself barely gets through the hole! By wiggling the gear, I can see that all it needs are nuts to tighten them down. The instructions, however, dont ask you to do this, and Im not sure if I received a set that had a flaw in it. Any ideas ? Thanks so much! Andy K
