Dr Honda
PA, USA Status: offline
rgoldy… Thanks for the tip in the landing gear pad. I will beef it up before my first flight. But as far as the wheel pants go… I probably won’t use them because the field I fly from is grass, and I’ll probably put taller tires on it. I too am surprised that the G23 wouldn’t pull it vertical. The knife edge doesn’t surprise me, since you are pushing 10#. But a G23 should produce more than 10# of thrust. What prop are you using? Perhaps you need a larger diameter, with less pitch. Also, APC’s are know to produce more static thrust (for good vertical) BUT… they are EXTREEMLY heavy. On my Wild Stick, I measured almost 500rpm, and 1.5# more thrust with an APC 18x6 wide, over my 18x6-10 Zinger. But… the APC weighed 160g, where the Zinger weighed 60g. I couldn’t afford to add 100g to the nose. (that model has the same prob your frenzy has, 12oz led in the tail) Just some random thoughts. Anyway… Last night, I had a chance to work on mine a little. I got a 6oz fuel tank mounted, (got to love gas) and I ran my throttle cable. I also, made up my muffler, got it mounted and test ran the converted motor. After the tuning… I shut it off for a few minutes. But when I came back, that little engine fired up on the first flip!! Right now, it’s spinning a TF 15x8 power point at a little over 7000rpm. I’m going to pick up a 15x6 to fly it on. And, it should rev closer to 7600rpm. (not bad for a $10 ebay motor) So, the last thing to do before the first flight is to mount the battery as far back as I can, and check the weight. I should be able to do that on Friday night. So, watch for my update then to find out what really happens with the balance.
_____________________________
Tony Owner of A&L Motorsports (formerly ARO Products) Manufacture of custom alloy parts.
