LDaba
NY, USA Status: offline
Aug: (interesting moniker ) I always use an air filter on my engines. You'd be surprised what an engine will ingest: grit, bugs,sand, bits of weeds, in short the flotsam & jetsom of life. (pretty poetic , huh? : ) A simple filter can be made out of a double layer of pantyhose cut to approximate size and held in place by an O ring. Its cheap and it works! ( how you get the panyhose is your affair ) The gasket couldn't hurt. I find I cant get a tight seal with some engines and an exhaust residue leaks from the joint. Gasket material is cheap and available from an auto parts store. Just trace around the exhaust manifold and provide openings for the screws and exhaust port and your done. I am not experienced with OS engines, so I can't offer any valid advice on their operation. I use Super Tigre and Webra engines. In these I use Tower Hobbies plugs and also Fox plugs. Both work well in either engine. Your last comment on not using a cowl will definitely assist in engine cooling. Don't forget that you are omiting weight that will affect the overall balance of the model. Weigh it exactly as you will fly it except DO NOT add fuel. While on the subject of balance, weigh it laterally. (wingtip to wingtip) If it has a heavy wing, it will tend to pull to that side on some maneuvers, especially at lower speeds.To laterally balance the model, suspend it inverted. Secure a string around the crankshaft and bottom hinge of the rudder. Check to see if the wings are level. If one is lower than the other, lift the plane slightly so the tension is off the string and you are supporting the weight of the plane. Lower the plane and repeat the test. If you get the same results, adjust the string (move it so that it will reseat itself around the crankshaft & hinge when you lower the plane)and repeat the test. If the same wing is consistantly lower, you have a heavy wing. Place weight on the high wing tip (I use sheet metal screws) until it balances. When they're level you have balanced the plane. Add the weight to the wing tip. ( I just screw them into the tip. I bevel the edge of the hole so the screw head is flush with the tip outline. I then spot cover the holes. Well that's it. Happy landings Tony
_____________________________
Keep 'em Flying Anthony Puleo, AMA11973
