replace drive gear and bearing
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Exceed RC Support - Nitro Cars >> replace drive gear and bearing
Page: [1]
Login
replace drive gear and bearing - 6/25/2007 5:15:37 PM
ToyDestroyer
Status: offline
I have an Exceed 1/10th Buggy. I recently stripped out the main drive gear. I ordered a new gear but the hex bearing out of the old gear does not fit the new gear. Do I need to buy a new bearing? Are there bearings from other manufactuers that will fit this? This is a 2 speed buggy and it is the larger 47 tooth gear that needs replaced. They should put a note on the parts list page of the manual that says the replacement parts aren't the same as the original equipment.
       Post #: 1
RE: replace drive gear and bearing - 6/29/2007 5:24:49 PM
{GBI}Harryball
Status: offline
Yea you should be able to get everything you need from allaboutfunhobbies.com they have a great selection of everything for you. You will have to look at the recat volcano parts, they will fit.
_____________________________
Sponsered by: ALL ABOUT FUN HOBBIES /ALL ABOUT FUN HOBBIES PRODUCT REVIEWER
(in reply to ToyDestroyer)
       Post #: 2
RE: replace drive gear and bearing - 7/3/2007 1:04:24 AM
AllAboutFunHobbies
Status: offline
That was a problem till recentlly you need this part
http://allaboutfunhobbies.com/store/catalog/product_info.php?products_id=811
It comes with the new outter hex to fit your new gear.
Dealer for...Redcat Racing, Traxxas, Team Associated, Cen, Racers Edge, RD Logic, Bodies by Blue, HPI, Himoto USA.....etc
       Post #: 3
RE: replace drive gear and bearing - 7/3/2007 5:44:32 PM
ToyDestroyer
Status: offline
AllAboutFunHobbies,
Is that the only part I need or do I also need to order the original hex bearing? Does that part replace the small bearing?
(in reply to AllAboutFunHobbies)
       Post #: 4
RE: replace drive gear and bearing - 7/4/2007 12:19:43 AM
AllAboutFunHobbies
Status: offline
That part comes with the smallbearing inside of a large hex that should fit inside your gear where the new hex hole is. The picture only shows the small bearing but it has a large hex around it.
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU5
